x189player
Post by x189player on May 27, 2006 13:46:32 GMT -5
A friend of mine needs help with his Squier Showmaster, H-H with 3way. The strange thing is this 3-way switch has 7 pins on the back, and all the Squier wiring diagrams show a 3-way with 8 pins. Anyone know the pinout diagram for this switch? or a diagram that shows it with 7 pins?
thanks, Paul
Post by Mike Richardson on May 27, 2006 19:02:08 GMT -5
While I can't say for sure, many of the less expensive switches have only one common lug instead of the usual two. This is very common on import Strat-types with the 5-way switch, but I don't recall seeing a 3-way like that. Having only one common lug means you have a one-pole switch instead of the usual two, which makes wiring a bit easier for the manufacturer.
x189player
Post by x189player on May 27, 2006 19:57:18 GMT -5
In that case, is it fair to say that the center lug is probably the same as the two center lugs (connected) on an 8-pin switch?
Post by sumgai on May 27, 2006 22:16:17 GMT -5
x, Yes, that's a fair assumption, but you know what the word "assume" does, don't you? ;D
Best to use a multimeter to make sure, before you wire it back up.
x189player
Post by x189player on May 28, 2006 12:00:31 GMT -5
heh, yes i do know that one. it would be easy if i just had the guitar in front of me- much harder to diagnose at a distance.
thanks, i appreciate the help.
Post by mike on May 28, 2006 12:56:49 GMT -5
