gpdb
Post by gpdb on Jul 5, 2022 15:12:14 GMT -5
Hi all, I'm trying to figure out how to create a bode plot for Fishman Fluence pickups. I'm a bit concerned about messing around too much because of the 9v in the circuit; I don't want to damage any of my equipment in the process of trying to figure it out. Has anyone tried this yet? I saw Antigua did an EMG, but this wiring seems different. I have mostly the same equipment that Antigua's main post recommends. I'm using a Velleman PCSU200 oscilloscope and Ken Wilmott's Integrator. Lastly, if anyone knows if I should or shouldn't be worried about the battery hurting my equipment, that would be really helpful. Here's the images of the pickup and the wiring guide:
I purchased some 9v connectors with alligator clips to be able to connect the battery into the circuit. From when I was learning to wire these previously, to change voices you just need the specific voice wire in the circuit. Voice 2 defeats the default Voice 1, and Voice 3 defeats Voice 2. So here's what I'm thinking for specifically the bridge pickup, for voice 1: - Red (9-18v) connected to the red (+) of the battery connector - Black wire from the pickup has a shield and a white wire inside; white wire maybe to the Integrator clip? It seems like the white wire and ground are similar to a South Finish with bare wire. - Black (-) wire from the battery to the other clip of the integrator? Then for the different voice, just connect the black wire with the voice 2 or 3 wire. Any help would be appreciated, I'd really love to see what these look like when plotted.
Post by stratotarts on Jul 6, 2022 9:30:20 GMT -5
First, 9V DC on the input test leads of the V5.9 integrator will not damage it. So don't worry about that.
I can't imagine, though, why there would be 9V in any measurement configuration. If the black shielded wire is the pickup output, as it appears to be, then the integrator leads should be connected:
ground (black/brown) -> black cable shield input (red) -> black cable inner white wire
You have to power the pickup normally, as it is an active pickup.
I am assuming you wish to make a normal output measurement, not something like a direct reading of one of the internal coils.
gpdb
Post by gpdb on Jul 7, 2022 13:10:19 GMT -5
Thanks for the help Stratotarts! I was able to create the charts with:
White output from pickup > Integrator Red Ground output from pickup > Integrator Brown
Then for the battery, I did: Red output from pickup > Red wire on 9V Black output from 9V wire > ground
I'll post a separate thread showing images of what I did and the charts I created. Measuring actives vs. passives is going to be a super cool piece of data to have.
Post by antigua on Jul 8, 2022 13:01:06 GMT -5
