Post by frets on Sept 4, 2022 11:15:12 GMT -5
For those who remember, I was working on an Ibanez harness with a VLX91 switch by Satan (OTAX). It’s for an HH and I could not get the coil splits to work at all. Dead. The other 4 positions work fine. And, I soldered according to not one, but two different official Ibanez diagrams (example below) with the same results. I then make the decision that it must be a bad switch. So like a moron, I ordered a new switch from Poland for $60.65. I solder it up, guess what, same problem - no coil splits. I throw it across the shop (Yes I did), and it skittered on the floor. That didn’t fix the problem. I have never had anything like this (and you all know, I’ve had a lot of “challenges”) happen before. The diagrams are fine. Got the wire color codes crosswalked. Checked the pin out. The switch is new (with a big scratch on it now). The user is obviously faulty. Does any soul out there have any theory as to why this is happening? - Desperate Cindi
Post by cynical1 on Sept 4, 2022 11:18:25 GMT -5
...Does any soul out there have any theory as to why this is happening? You didn't throw it hard enough...
Post by unreg on Sept 4, 2022 23:00:21 GMT -5
frets- … EDIT: You did test the switches before wiring? I assume you did but had to ask. Resistance tests give a much more detailed idea about how your switch is/isn’t working (that opposed to continuity). Maybe testing continuity is all you need here? [EDIT]But, obviously, two similar-model switches returned the exact same problem; so, the diagram or its implementation is probably the culprit. It’s just that you said the diagrams are fine; so I, with my lack of experience, concluded that your switches probably both have the same problem.[/EDIT]
Post by Deleted on Oct 8, 2022 16:45:23 GMT -5
For $60 I'd make you a switch! So think more can be done for cheap
jaymenon
Post by jaymenon on Dec 18, 2023 4:58:08 GMT -5
From my understanding, the magnet on one of the pickups needs to be flipped - so the magnetic polarities of the two humbuckers are now opposite. Only then will the inner coil of each pick up selected together be hum-cancelling.
I believe the DiMarzio/IBZ pickups come, that way as stock.
Post by newey on Dec 18, 2023 5:54:33 GMT -5
frets-Did this issue ever get solved? To clarify, the issue was only at switch position 2 where the coils are split? Piezo, everything else works OK? jaymenon- Her problem was no coil splits at all, not that they didn't hum-cancel
Post by frets on Dec 18, 2023 12:49:49 GMT -5
Newey,
It remains the biggest enigma of my wiring career. No splits at all - ever. I refuse to work with those switches. I even bought a new one, still didn’t work. I have no idea what it was. It wasn’t the pickups.
Post by ssstonelover on Dec 18, 2023 15:54:35 GMT -5
I looked around and found a differences in the drawing version you used and another with the same switch and the same alleged functions I highlighted it in a pink box. This may hold the secret (possibly). Note: I did no wire tracing, just a wire comparison. Both the while and black wire jumpers are different here. If you click the image a second time (after it opens in Postimage) it seems to expand nicely. If you have any issue, I'll send the image to your mailbox, just let me know.
Post by frets on Dec 19, 2023 14:21:31 GMT -5
Ssstone, Thank you for the diagrams.
