Post by melodianchew on Dec 20, 2022 5:10:05 GMT -5
Hello, Fellow GuitarNutzians:
Ive been coming to this, my favorite guitar flavored web site, ever since there was only a GN1, though this is my first ever post. I thank you all retroactively and in future tense, for all your great help and instruction.
I have been dabbling in electronics modification and design and its theory for a long time although in a purely amateur capacity, and with no schooling, nor a mentor, and have unfortunately had to rely on my auto-didactic nature to push me through concepts and learning. I have a greater working knowledge of electronics than I do a theoretical one, born form reading, experience and experimentation. The theoretical lack no doubt as a consequence of a lack of any formal instruction. But I yearn for knowledge of it eagerly.
So, in my famous loquacious nature, I will have probably killed the interests of many prospective experts that might offer opinion, likely abandoning the post by this point due to its verbosity, but I felt like it might possibly help (me) in some fashion if I could first in advance try to give said prospective experts license to expound on a more technical or theoretical level, if they might feel so inclined, perhaps if just for this particular post.
For, although there is a vast wealth of information available on the net to the complete novice on just about any subject, it seems like that instruction or information that is at a more intermediate or advanced level is very often difficult to come by, and it is a light glazing of such that I seek here. I full well understand that the difficulty in providing information that is more advanced is that it requires an assumption of knowledge of basic fundamentals which can be tedious to have to provide for initiates. So, please dont be afraid to be technical.
Now, incidentally, I prefer single coil pickups generally and have had GREAT success in attenuation of the inherent hum and artifacts they so naturally display through the many wiring and shielding techniques that I first learned about for noise reduction here on GNutz, but that success has just brought me more questions actually.
So, The questions in this post are aimed specifically at the particulars of shielding and wiring and best practices of it and why, and my hope here is obviously in taking a shot at getting a much better grasp of some of the theoretical aspects of grounding, hum, noise, and its causes, as they specifically relate to the guitar and its wiring, through posting a range of questions that I have gathered, that I would like to have more clarity on, or which I hope will at least fill a few holes in the container i use for holding such knowledge. At the very least I believe that this topic could foster some interesting discussion. Sorry for the novel, and thanks again:
QUESTIONS:
1) Generally speaking, which side of the circuit is it more important to ensure a quality of a connection for, the signal or the ground side?
2) Which side would benefit from having a larger diameter wire, ground or signal?
3) Shortest leads possible are best right?
4) In which specific connections is attention to wire length most critical?
5) I have read that in a guitar, the wire diameters need only be of minimal diameter and that using thinner wires helps by providing a smaller antenna for noise since the currents in that circuit are so small, larger wire is not needed and will only introduce capacitance. True, or am I off base somewhat?
6) Would the old solid, and not stranded copper wire type of Ma Bell telephone wires be a good choice for guitar circuits? Being solid and not stranded, it is extremely thin, seems easier to work with, solders and attaches just like component leads, has no twisting or flaying of strands to have to contend with and is easy to strip and tin. And with the recent obsolescence of the trillions of miles of wire available, sometimes free for the taking, it seems like a perfect choice. And if you are lucky enough to be able to happen upon an old defunct Terminal panel or hub, you can sometimes find it in very long lengths and in a huge array of colors. So, given the short lengths needed inside a guitar cavity, isn't it a perfect choice for leads that won't benefit from shielding like the ones going from the jack to the volume pot?
7) Twisting the leads of pickup wires helps with noise right? how tightly twisted?
8) Are the number of twists per inch that are necessary in a pair of twisted wires a function of the wavelength of the noise signals likely to induce into the wire?
9) I have seen some posts characterize the ground wire connections that normally exist, in say, a standard strat wiring scheme, that are connected between tone and volume pot shells, as unnecessary, IF shielding is present and continuous under pot mounting points. They were characterized as potential ground loops and if the whole cavity was shielded were better left off. Then another post claimed best practice was to consider them signal returns and therefore necessary and best practice is NOT to rely on shielding for that purpose. So which is more true and what factors determine making the best decision between the two?
10) I shield the inside of my jack route as well, is this a best practice? Or is it really unnecessary if the lead is shielded coaxial wire?
11) When using shielded leads, it is better to use a two wire with braided shield, as in1 signal, 1 ground, and a braided shield that's grounded on one end, or, is just a simple single signal wire wrapped in a shielded braid that is used as ground a better choice for the lead going from jack to volume pot?
12) Which side is it best to attach the braided shield to ground to in a shielded wire, the jack side or the pot side and why?
13) When shielding the cavity of my guitar i generally prefer copper tape with a conductive adhesive. How critical is ensuring a uniform measure of low resistance between any two points of the shield? How will that affect things?
14) Am I wasting my time in efforts to guarantee much more uniform conductance between tape layers if i will lay down in the cavity and across the pick guard, a continuous flat bunch of thin bare wire strands that i have spanned and are touching across all of the pieces of the tape sections that i cover with another piece of copper tape to hold it all cleanly down in the cavity?
15) I work hard to achieve a small continuous "gasket" of the copper tape i use to shield the cavity with that I fold outside of the holes and lay flat against the top of the guitar such that the shielding of the copper tape on the pick guard will touch and lay flat against it so as to maintain a better continuous connection around the whole border of the connection point between the pick guard and the guitar body. Is this level of meticulousness helping much?
16) Is a shield that i have gone to this much trouble to ensure the continuity of one that might make the keeping of the ground wires between pot shells, that are normally used as signal returns, unnecessary?
17) How detrimental are cold solder joints to the tone of the guitar?
18) Why does hum get louder or quieter based on the direction i am pointing my guitar?
19) Why does hum gets quieter when i touch the strings or metal pieces of hardware?
20) Why would the hum get louder if i am touching the strings or metal of my guitar?
21) If we are preserving the ground wires between pot shells as signal returns, doesn't this destroy my attempts at achieving a star type of grounding?
22) Why aren't the connections between the pots made by their shells in their attachment to the pick guard shield not considered ground loops?
23) Should I be concerned with a potential for corrosion that i might induce in a circuit at connections where the metals differ? is it the amount of current running through the circuit that determines the extent of the corrosion potential? is the current in a guitar circuit too low to worry about this condition? does having the solder in a joint of two differing metals help mitigate such fears?
24) In order for ground loops to exist is it a difference of resistance or impedance between the two different connections that is causing it?
25) Now that I have exposed just how profound my ignorance on this subject is, is there anything else you think I might like to need to know about it?
Ok, I'm gonna be a real Captain Obvious here but, one might answer any of the questions by simply typing the number the answer pertains to then answering, like in this fashion, for instance as if this might have been your reply to #25 :
"25) Yes, you ARE quite profoundly ignorant, and SO profoundly so, that I have started to consider that maybe ignorance DOES also imply an existing component of stupidity, and therefore have decided I should not even bother trying to answer for risk of confounding you even further by providing you any other details."
(sorry, the class clown in me just couldn't resist)
one need answer only one or all of these questions...
Thank you for all of your help,
Scott
The RedneckSage
gear:
every unnecessary note possible on my 1997 Frankenstratosquire "double plus deluxe" with large head stock and maple neck with mismatched single coil pickups through a modded '65 Gibson Lancer RVT.
