Post by nickbachman on Jun 12, 2006 21:35:43 GMT -5
greetings. i recently installed a push pull pot on my squier tele custom to coil tap the bridge humbucker. i wired it up and it works fine, except when it's pulled out, it's the full humbucker, and when it's pushed in, it's tapped. how can i switch that around?
Post by johan on Jun 13, 2006 6:15:55 GMT -5
you will have to switch the upper and lower terminals
1 4 2 5 3 6
In two different switch positions, 2 an 5 connect to 1 and 4 respectively in one and to 3 and 6 in the other positions.
To the point: Solder the wires connected to 1 and 4 to 3 and 6 and the ones originally connected to 3 and 6 to 1 and 4
good luck
Post by gumbo on Jun 13, 2006 7:03:47 GMT -5
...which comes back to that oldy-but-a-goody about sliding vs toggle......but johan's absolutely right!!...:-)
Post by nickbachman on Jun 13, 2006 17:24:28 GMT -5
hmmm. that's confusing to me, because i wired it up like the seymour duncan schematic said to, like this: where do i go from here?
Post by fobits on Jun 13, 2006 19:03:06 GMT -5
On your drawing, just move the black ground wire from the lower right to the upper right.
IOW the black wire which is below the red & white ones should be moved to the terminal above them.
That should do it.
Post by nickbachman on Jun 13, 2006 21:17:44 GMT -5
problem solved! thanks fobits!
