yesfan2
Post by yesfan2 on Aug 20, 2006 2:26:36 GMT -5
Post by ccoleman on Aug 20, 2006 6:23:12 GMT -5
what do u mean by "the signal drops a lot faster".... ?!
yesfan2
Post by yesfan2 on Aug 20, 2006 13:43:14 GMT -5
<< what do u mean by "the signal drops a lot faster".... ?! >>
It's like after you strum a chord, normally, it take say 5 seconds for the sound to fade away, but in the Center-Neck position, it fades away in 2.5 seconds.
Post by ccoleman on Aug 20, 2006 13:53:22 GMT -5
Probably the magnets are pulling on the strings and slowing them down.
Try lowering your pickups away from the strings and see how that makes a difference.
Post by UnklMickey on Aug 21, 2006 9:59:22 GMT -5
hi Yesfan2, welcome to GN2. i don't have a good answer for your question, and unfortunately i don't think the previous answer was very good either. Probably the magnets are pulling on the strings and slowing them down.... no offense intended, CC, but that doesn't fit the symptoms. if the magnets were killing the sustain, they would do so regardless of which pickups were selected. they don't get closer to the strings, just because the Neck-Center combo is selected. cheers, unk
Post by ccoleman on Aug 23, 2006 6:50:29 GMT -5
good point unk...
I was thinking "magnets" in the sense that posibly a coil would be shunted and sucking out tone in that combo.
another possiblity: the combo is OOP and after 2.5 sec more or less cancels completely.
Post by Happyguy on Aug 23, 2006 14:39:16 GMT -5
I think he should review his wiring job, If it's a phasing issue he would be getting inside out thin tin can noise. But meby that is the case. I don't know. I would just double check everything to make sure before we look for bigger problems.
