pandejon
Post by pandejon on Dec 7, 2006 21:59:22 GMT -5
Post by UnklMickey on Dec 7, 2006 22:34:53 GMT -5
hi pandejon, welcome to GuitarNuts2. your English seems just fine so far! the answer to your 1 st question is YES. unfortunately there is a problem with the Seymour Duncan link you provided. did you mean this one? www.seymourduncan.com/support/schematics/2h_2v_1t_3w_pp.htmlif that is not right, and if you can't get the link you wanted to post properly, just type out the name, like: 2 HB, 1 volume, 2 tone, 3-way, 2 push-pulls. or whatever drawing you mean. we'll know how to look it up on the SD site: www.seymourduncan.com/support/schematics.shtmlthen someone will be able to answer your other questions. things happen somewhat slow on this board, so be patient. cheers, unk
pandejon
Post by pandejon on Dec 8, 2006 2:53:32 GMT -5
Post by UnklMickey on Dec 8, 2006 16:49:57 GMT -5
...Now I desperate for the answer no 2 and no 3, if possible.
Somebody pleaseeeeeeee........ you sound so desperate and needy. relax, take a breath. the red Xs show where connections will no longer be made. i didn't eliminate the wire that goes from the top 2 poles (center column) of the toggle to the ground at the volume control. it doesn't matter if you leave it, or remove it. the blue lines show new connections that you need to make. #3 - you could do other things like series/parallel, a phase switch, or a Jimmy Page wiring scheme, but that would require more push-pulls. i'm not interested in putting anything together like that, but maybe someone else might be. cheers, unk
pandejon
Post by pandejon on Dec 10, 2006 7:00:53 GMT -5
unk, thank you very much for the diagram.
I don't know how much I owe you, hope good karma always follow you on this and next life
Thanks again
pandejon
