OK, but I only see two knob locations on the '51. I presume that you'll be a drillin' a third "well".
OK, be sure, however only one needs to have 2 wire plus shield.
Yep!
We'll do a 3 pole design.
Pole 1. Bridge hot output (Bh). Bridge return lead to common (ground).
Pole 2. Neck hot output wire (Nh)
Pole 3. Neck return wire (Nr)
Pole 4. Like a different tone cap value for each position or sumpthin'. Be creative (after you get the basic circuit to work).
We have these other designations:
Vol hot lug (VhL)
Vol wiper lug, goes to Jack tip
Vol common lug, goes to common (ground), Jack sleeve
Jack Tip, the terminal that attaches to the tip end of the cable
Jack Sleeve the terminal that attaches to the barrel of the cable
The TBX, which I presume you'll use the Fender documentation for.
(Do you see where this is leading?)
I will state the connectivity for each of the 6 combo's. You can put them in whatever order you like on the actual switch.
1. Bridge
PBh - VhL
PNh
PNr
2. Neck
PBh
PNh - VhL
PNr - Common
3. Bridge in parallel with Neck
PBh - VhL
PNh - VhL
PNr - Common
4. Bridge in parallel with OOP Neck
PBh - VhL
PNh - Common
PNr - VhL
(You might want to try a 0.022 uF cap between PNr and VhL here for that parallel 1/2 out of phase as on the Jerry Donahue Tele.)
5. Bridge in series with Neck
PBh - PNr
PNh - VhL
PNr - PBh
6. Bridge in series with OOP Neck
PBh - PNh
PNh - PBh
PNr - VhL
1. Bridge
2. Neck
Hollow, weak, and tinny sounding, may be improved with cap in series with neck (or bridge) pickup to vol pot.
Hotter, middy sounding
Hollow sounding, one of my favorites
I don't know what the actual switch wiring looks like, but with it being an exposed wafer switch, you can just physically look at it and learn. I will also presume that you posses a digital multimeter and will measure things as needed.
Here's a nice reference document for general guitar wiring info:
www.stewmac.com/freeinfo/I-3200.html?'nuff info?
