darkcyde
Post by darkcyde on Jan 11, 2007 20:30:51 GMT -5
Hi, Well I am redoing my Ibanez again. I just bought two push/pulls to add to it and was wandering what the best combo would be for:
2 humbuckers 2 Push/pull pots 1 on-on-on toggle 1 5-way blade switch
Would like to see what others have done with similar setups
Post by gfxbss on Jan 11, 2007 23:32:43 GMT -5
darkcyde
Post by darkcyde on Jan 12, 2007 10:38:57 GMT -5
Oh, I wanted to mention that I can add another on-on-on if needed. It would make things to tight (topside) with it but it could be done. I just want to find a way to get as many combos out of the two HBs as possible. Guitar specs/Mods: Ibanez RG 320 QM DX Stock Ibanez bridge but its been blocked Sperzel locking machine heads metal film rear cavity as well as the pickup areas 80s DiMarzio PAF pro in the neck Stock Bridge pickup [removed from guitar] I had added a rotary tone switch in middle of the stock vol/tone holes. This left a hole that is now filled with an On-On-On dp switch that is unwired(hole filler at the moment) This brings us to the two push/pulls. I am wandering if you can get every combo with those and two On-On-On switches? (or at least close) Thanks in advance for all the help guys! DC
darkcyde
Post by darkcyde on Jan 14, 2007 22:45:52 GMT -5
Ok, maybe this will make it easier. I made a quick template for this combo. Please feel free to modify as you see fit, as I could really use the help. thanks in advance DC
Post by borsanova on Jan 16, 2007 9:47:38 GMT -5
Why don't you take a look at my broadbucker design? I've just posted two new schematics that could do for your case.
