bignoot
Post by bignoot on Jan 28, 2007 22:28:34 GMT -5
Ok, guys I can follow a wiring diagram, but I have changed out the pickups in a Squire strat with Tex Mex, and changed the 500k pots with 250's, and now the hum is worse when I touch the strings. As a matter of fact it is more a buzz than a hum. What did I do wront???
bignoot
Post by bignoot on Jan 28, 2007 22:29:15 GMT -5
I mean wrong? ?
Post by gfxbss on Jan 28, 2007 22:49:50 GMT -5
hey bignoot, first off i would like to say Welcome to GuitarNuts2. to me, it sounds like you have a ground wire that is loose. Open it back up and make sure everything is grounded correctly. here is a stock wiring diagram for a tex mex strat. also, may i suggest the Quieting The Beast Modfollow these two closely, and your strat should have nearly no hum/buzz and should sound great. Tyler
bignoot
Post by bignoot on Jan 28, 2007 23:33:10 GMT -5
Thanks for the welcome, I have checked all my solder joints, and all seem to be solid. I also failed to mention that I changed the wire size to match the size on the pups. (20) I may have used the wrong wire, but I don't see how. Before all these mods, there was little if any buzz or hum to this guitar. I used electronic solder, so this doesn't make sense to me.
Post by gfxbss on Jan 29, 2007 6:23:38 GMT -5
try taking a multimeter and testing the resistance on the fround wires.
Tyler
Post by Happyguy on Jan 29, 2007 10:03:11 GMT -5
Sounds to me like hot and ground were reversed on the output jack. Possible? What kind of sounds do you get out of the amp?.
Post by UnklMickey on Jan 29, 2007 10:39:35 GMT -5
Sounds to me like hot and ground were reversed on the output jack. Possible? What kind of sounds do you get out of the amp?. probable! this is a very easily made mistake.
Post by gfxbss on Jan 29, 2007 15:27:41 GMT -5
ahh, didnt even think of that one. good call.
i know ive made that mistake a few times....
Tyler
bignoot
Post by bignoot on Jan 29, 2007 18:01:38 GMT -5
It doesn't look like it to me, but I am willing to try anything. The sound out of the amp is quiet till I touch the strings, then noise from you know where. I will look again, and will try changing that, that is easy enough. bignoot
bignoot
Post by bignoot on Jan 29, 2007 19:51:35 GMT -5
Ok, you guys, I did a silly thing. I did put the wrong wire on the output jack, and I had to go to the Fender site to get one that you could read. While I was in there I changed the cap to a .022. Boy what a difference the whole thing sounds like a real guitar. Thanks guys, you are the best. Bignoot
Post by gfxbss on Jan 29, 2007 23:13:06 GMT -5
awesome man. like i said before, it is a mistake i have made many many times. it always confuses you at first, then you feel dumb. just be reassured, there are more out there that have made this mistake!
Tyler
