dfrank
Post by dfrank on Feb 28, 2007 21:15:08 GMT -5
I'm a noob, I'm in the middle of redoing my telecopy I have had since 1982.
I decided to put in copper shielding tape I got from Stewart MacDonald. I put this in the pot cavity, the bridge pickup cavity (which is contiguous with the pot cavity) and the output switch cavity. I had it in the tailpiece cavity, but took it out because I couldn't get a clean test on the switchcraft jack -- it would ground out half the time on the meter when the cord was inserted.
Now I'm having some troubles with grounding -- I am putting it back together little by little and checking everything with the meter.
This is a 2-humbucker tele setup with the LesPaul style bridge-both-neck output switch above the strings. It has a large pickguard to cover all the cavities.
That LesPaul style switch, great piece of electronics, except that it is pretty large and has 4 exposed tabs the signal lines and ground line solder to, any one of which could very easily make contact with the copper shielding.
I am looking for solutions -- should I tape everything, and if so, with what? I don't want to just start taping everything in sight; like I implied, I think the LesPaul style switch is the culprit right now.
I bet many here have been down the shielding road before. I have been sofar unsuccessful using the search option -- probably ignorance on my part of "what to search for".
Thanks for your time,
dfrank
Post by dd842 on Mar 1, 2007 11:42:45 GMT -5
Hi dfrank, and welcome to GN2! I'm a noob, I'm in the middle of redoing my telecopy I have had since 1982. Wowsers! If you're a noob, I don't know what I am ... sperm? ;D ..... Now I'm having some troubles with grounding -- I am putting it back together little by little and checking everything with the meter. ..... That LesPaul style switch ..... could very easily make contact with the copper shielding. I am looking for solutions -- should I tape everything ..... Tape tends to fall off (loses it's adhesiveness) over time - so you may be better off with a similar idea, but using something else. For some reason, I am picturing using a little bit of a thin plastic lid of a margarine (or whatever) tub to fashion a bit of a "collar". Perhaps that could be a tidy and permanent solution? Sorry I can't come up with anything better than that. Dan
dfrank
Post by dfrank on Mar 4, 2007 22:19:17 GMT -5
Dan,
It's a good idea and it seems to be working. Signal and ground now measure as expected with the meter.
Thanks for the help.
David Frank
Post by dd842 on Mar 5, 2007 9:40:00 GMT -5
Dan, It's a good idea and it seems to be working. Signal and ground now measure as expected with the meter. Thanks for the help. David Frank David, Glad I could help! Having had the guitar since 1982, it must be a real favorite after all this time. All the best, Dan
