richardf
Post by richardf on Jun 17, 2007 9:41:11 GMT -5
???I have just purchased a set of pickups for a Tele. The pickups are Fender Custom Shop Texas Special pickups for Telecaster.
The bridge pickup has two wires -- no problem there.
The NECK pickup has three wires. One black, one white, one yellow. Can someone please tell me what each of these three wires are.
For bonus points you might add on something about wiring the 3 wires onto the 3-way switch.
Thanks a million.
Richard
Post by ChrisK on Jun 17, 2007 21:13:48 GMT -5
Welcome a'board!
Well, two are probably for the coil and the third is likely connected to the cover for shielding purposes.
Take your digital multi-meter (you DO have one, right?) and measure the resistance between each wire and the others. Write it down and keep it with the case that the pickups came for future reference.
(Wiring a guitar without a digital multi-meter is like driving with your eyes closed. Just say no.)
For the two wires connected to the coil you should measure around 5,000 to 10,000 Ohms. If the third wire is connected to the cover, you'll measure around 0 Ohms from the nickle silver cover to said wire. If all three wires have 1,000's of Ohms to each other, the third wire is a coil tap.
As I mentioned, measure between all three wires (6 readings, three of which should be redundant) and the cover and post the results.
I suspect that the third wire is the cover shield connection because these are custom shop pickups that may be wired with the Tele 4-way switch and would require a shield NOT connected to either coil wire for the series coil mode.
As to the meaning of each wire color, I don't pay attention to such until I wire things in after measuring everything always anyway. Others aboard will know such detail perchance.
One of the bridge pickup wires will probably be connected to the bridge plate thru the mounting screws to effect the bridge plate ground connection.
Post by RJB on Jun 18, 2007 11:15:39 GMT -5
richardf
Post by richardf on Jun 18, 2007 11:24:59 GMT -5
Thanks a lot to RJB and especially to ChrisK for taking the time to give a good answer. I do have a multimeter, and I am printing out all of this info for my project. I will be back both to give and receive the good advice found here.
Richard Thanks.
Post by ChrisK on Jun 18, 2007 16:21:08 GMT -5
Technically speaking, of course.
