gumby131
Post by gumby131 on Jul 4, 2007 1:11:24 GMT -5
im build a guitar and want a stainless steel scratch plate, could this work?
Post by michaelcbell on Jul 4, 2007 7:48:04 GMT -5
scratch plate?
Post by sumgai on Jul 5, 2007 3:05:52 GMT -5
Australian for pickguard. And gumby, yes it would work, but it would cost more than the rest of your axe! sumgai
Post by gumbo on Jul 5, 2007 7:48:08 GMT -5
Ha!...
and it WASN'T me who asked that, SG....... :-)
Post by michaelcbell on Jul 5, 2007 9:31:01 GMT -5
but it'd be a darn good shield!
zamzara
Post by zamzara on Jul 5, 2007 9:54:53 GMT -5
Post by sumgai on Jul 5, 2007 12:34:13 GMT -5
Gumbo, You already are from down under, so I didn't think you'd have to ask. 'Ave a g'day, mate! sumgai
Post by sumgai on Jul 5, 2007 12:35:59 GMT -5
but it'd be a darn good shield! Yeah, thrown beer bottles wouldn't even scratch it! ;D
Post by UnklMickey on Jul 5, 2007 21:55:38 GMT -5
If you are making your own, machining stainless can be a bear. Brass and aluminum are much easier to work with.
Post by strathappy on Jul 21, 2007 1:54:18 GMT -5
Aluminum is easier to cut, but much more of a pain to grind down if you don't get it cut out very close to desired shape (it clogs up grinders, wheels, files), here's my custom pickguard...it took 6 hours total to make, I can cut that in half now that I have the right tools (drill press, scroll saw, etc). I had to drill 21 holes and then chamfer 19 of them for the screws... the edges had to be grinded down to a slanted angle, I used a metal wire brush accessory on the dremel to burnish the metal for a cool, almost pearloid look to it (shiny diamonplate would look horrible glam, not to mentiion every scratch and fingerpring would show.
hugh
Post by hugh on Jul 21, 2007 11:59:13 GMT -5
Post by strathappy on Jul 22, 2007 21:46:28 GMT -5
Well the guy that started this thread said he was building a guitar so I assumed he would be pretty hands on and want to build his own.
I checked out your link and it says "Plastic guards rely on aluminum foil backings where ours do not because they are solid aluminum. You will notice less feedback and clearer tone due to a solid ground. " I did notice the tone sounds better, and I do have less feedback actually, which in my case is a bad thing, hahaha...but how does it create a stable ground, I thought aliminum was no good for grounding??
Post by wolf on Jul 22, 2007 22:58:30 GMT -5
Post by strathappy on Jul 22, 2007 23:11:04 GMT -5
YUCK, I would play that if I looked like Frankenstein!!!
Post by wolf on Jul 22, 2007 23:54:57 GMT -5
Well then it is easy to guess why it is being discontinued. ;D
Post by sumgai on Jul 23, 2007 3:38:14 GMT -5
strathappy, Sorry, you almost slipped through a crack there....... Aluminum is fine for carrying electrical signals (or power, some houses have aluminum wiring), but it's harder to work with. You almost can't solder it, it dissipates heat too quickly, so you have to make physical contact between pieces, and hope for the best. Shielding-wise, many members here have done the "Quieting the Beast" job with aluminum foil, and reported great success. If you've got it, use it with confidence, given the foregoing. Hmmm, a pickguard made of solid aluminum will deliver "clearer tone"? I think that'd be subject to the listener's interpretation. Since it can't be easily quantified, it probably wasn't smart of them to make such a statement. ;D But I can say, such a beast won't give you any more protection against hum or buzz, the job requires only so much thickness (not very much!), and anything more is overkill. Squelching feedback would be because it doesn't resonate at the same frequencies as the strings and body/wood. That large a piece of metal will act to dampen any such resonance before it can become feedback. As you noted, this can be good or bad, depending. HTH sumgai
dsrb
Post by dsrb on Jul 23, 2007 7:04:34 GMT -5
Maybe you like Zemaitis ;D:
Post by strathappy on Jul 25, 2007 2:00:34 GMT -5
I made another diamondplate pickguard for my SG, I love it!! This one was much qucker to make with the scrollsaw. Traced out an idea on paper: Finished result: That is all.
hugh
Post by hugh on Jul 26, 2007 1:07:47 GMT -5
very cool.
