jpbracken
Post by jpbracken on Oct 26, 2007 14:02:42 GMT -5
I was just wondering how important it is to ground the bridge? (Tune-O-Matic if it makes a difference) I know not grounding it would make electrocution less likely (always a good thing ;D), but how would it effect hum? And would good enough shielding prevent hum in a guitar with no bridge ground? Thanks for any help -John
azrael
Post by azrael on Oct 26, 2007 14:19:05 GMT -5
Well, does your guitar stop a bit fo a hum when you touch the strings?
Post by ccso8462 on Oct 26, 2007 14:36:06 GMT -5
Your best bet is to give it the works: A capacitor for safety, shielding and grounding for hum cancellation. That way you've covered all the bases.
Carl
Post by stratatouille on Oct 26, 2007 14:50:09 GMT -5
M. jpbracken wrotes "I was just wondering how important it is to ground the bridge? (Tune-O-Matic if it makes a difference) I know not grounding it would make electrocution less likely (always a good thing ;D), but how would it effect hum? And would good enough shielding prevent hum in a guitar with no bridge ground?"
Bonjour, M. jpbracken,
Grounding the bridge is very important part of reducing the hums - without it, even good shielding could not really change the hum.
Electrocution occurs when you is having use of a faulty old amp plus you are in contact with another piece of equipement and in such an environment it it allows electrocution.
Since you DO have to ground the bridge, the safety from electrocution is where the .33uF 400V capacitor is comes in.
While electrocution is unlikely, better safe than sorry, yes?
And at about only $1 for a capacitor, there is no excuse to not do it. Okay.
M. Strat
Edit: I see that I has been repeating some of M. csco8462. Sorry.
jpbracken
Post by jpbracken on Oct 26, 2007 14:51:02 GMT -5
The bridge ground is connected on the guitar and does stop hum (although it isn't shielded). I was asking more out of curiosity than anything else. (Is it possible to have a guitar with no bridge ground and no {or almost no} hum)
-John
jpbracken
Post by jpbracken on Oct 26, 2007 14:52:17 GMT -5
and thanks for the swift replies
Post by ccso8462 on Oct 26, 2007 17:23:29 GMT -5
Nothing to be sorry for, M. Strat. You gave a little better explanation than I did. Thanks for the assist! Carl
