Post by mattvincent24 on Nov 2, 2007 18:45:24 GMT -5
I need some wiring help!
I have a strat with 2 single coils and one humbucker in the bridge. Now what i would like to do is have a standard wiring config. but by use of a additional on/off switch have the neck and bridge pickups turned on with a blend control and a tone control in the circuit. I can add another pot for the blend control but would like to use one of the existing tone pots of the tone control. I know this is possible but i couldn't quite figure it out....please help!!!!
Post by ChrisK on Nov 2, 2007 21:13:49 GMT -5
Search for "Blend" on this forum. Designs like these also abound a'web. You'll need to interpolate between the two (mix and match) for what you want. If you can't "see" it, let me know. Note; If you use an existing tone pot, the taper will be backwards unless you use counter-clockwise rotation for blend in.
Post by warmstrat on Nov 4, 2007 16:05:00 GMT -5
