Post by christianbassist on Nov 30, 2007 22:33:15 GMT -5
How would i use my tone knobs on my strat to use it ad a 2-band eq circuit? is this a hard mod?
Post by ChrisK on Dec 1, 2007 0:53:37 GMT -5
The tone controls on a Strat are not band pass/reject circuits, but low-pass, high-cut only circuits. Only an active electronics module (and a battery) will give a true equalizer control system. However, a system like that used by G&L works as a low-pass on one knob and a high-pass on the other. Note that C3 is not needed and only reduces the high frequencies. Removing it will make the guitar sound brighter. VR3 and C4 is the traditional low-pass, high-cut tone circuit from a Strat. VR1 and C1 is the low-cut, high-pass circuit. Note that C1 is 0.002 uF and not 0.022 like C4. C2 is a traditional high frequency bypass that helps preserve the high frequencies when the volume control (VR2) is turned down.
