Post by uberdavidson on Jan 10, 2008 22:20:11 GMT -5
I want a strat with these combinations.
1. Humbucker (Bucking the Hum) 2. Humbucker (One on, One off) 3. Humbucker (Bucking), Mid, Neck 4. Mid, Neck 5. Neck
I am not sure on the wiring of such a combination, oh yeah Bridge and Neck have seperate tone knobs.
Tanks, Sean
Post by ChrisK on Jan 11, 2008 21:25:40 GMT -5
Number 5 is alive.
It needs more input.
Post by sumgai on Jan 12, 2008 14:21:19 GMT -5
Sean, Hi, and welcome to the forums! ;D So, what Chris is saying, besides showing off his erudition for old movies, is that we could better help you if we knew what kind of switches you have (or want to use), how many leads come from the humbucker, and whether or not you want series combinations, parallel combos, or both. And within the humbucker, we can do the series/parallel thing all over again (providing you've got four leads coming out, plus the shield wire (which is usually a wrap around the other four)). And all that's not to mention, phase reversal might be desirable too. I might ask you to take a peek at some of our "finished" diagrams, in the Schematics sub-forum. Most of them have more "features" than your request, but when that's the case, then they are easily adapted to your needs by simply removing the unwanted stuff. Other diagrams can be found in this forum (Electronics and Wiring), take a closer look here too, after checking out Schematics. Punt! The ball's in your court, my friend. HTH sumgai
