Post by ChrisK on Jan 14, 2008 20:51:13 GMT -5
Welcome a'board, and, er, hold yer water Sparky! Someone will (and has) come along when they have the (free) time. This is A Mike Richardson design. There are others that may already do most of what you want. Here's one that I drew up and have used. Mike Richardson wiring with phase. It does the following: 1. B 2. B+M 3. B+N 4. M+N 5. N and 1. B+M+N 2. B*M 3. B*N 5. M*N 5. B*M*N I also added out of phase switching to the neck and bridge pickups. It doesn't do Middle alone, but then I don't use that anyway. Well, they're capable of a lot (4P5T), but the "lot" isn't known until the design is developed. Yes, see our "Schematics" section. (It's called "homework".) Are you asking if one can design something specifically for you, or are you asking if one can enable you to design something specifically for you? "How lucky do you feel?"
