Post by hondavfr800 on Feb 12, 2008 7:05:11 GMT -5
Hi All... I Did the following wiring on my guitar: now I'm supposed to have the bridge pickup working with the rest of the pickups (push pull pot), and it works, but the problem is that it sounds thin when I use the bridge + other pickup (mid or neck) and it sounds ok when in "normal" use (i.e neck+mid, mid, bridge+mid, bridge) Pickups are: Bridge - Dimarzio FastTrack 2 (DP182) (4 wire) Middle - Dimarzio HS-2 (4 wire) Neck - Fender Tele "Lipstick" (2 wires) Guitar is Peavey Predator. P.S - the wire coming from the volume pot into the 5-way switch is soldered to 2 poles on the switch, slightly different than in the schematic above, AND while previewing this post... I discovered that I forgot to link between the volume pot ground and the tone pots ground. I'll go back and finish the job... but if you guys have any ideas of what might went wrong or anything, please tell me Thanks. will report later. EDIT: My pots are 500k
Post by sumgai on Feb 12, 2008 12:23:25 GMT -5
Post by hondavfr800 on Feb 12, 2008 16:57:11 GMT -5
Thank You!
Works like a charm - Sounds like a mother$@#$% ;D
At first I used the red wire on the fasttrack as hot, and grounded the green wire.
After your advice, I just "switched" between the two and the magic happened :-)
Thank you Sumgai - you're a real life saver!
