d34th4uall
Axeman Custom Axes
Post by d34th4uall on Jul 19, 2005 22:11:00 GMT -5
repairing an old 6 string that my grampa beat the crap out of. needs some serious truss rod adjustment, but the nut is stripped out(thanx g-pa). any suggestions on how to get it out and replace it with out removing fretboard?
wesman
Post by wesman on Jul 20, 2005 7:13:00 GMT -5
d34th4uall
Axeman Custom Axes
Post by d34th4uall on Jul 20, 2005 13:27:36 GMT -5
yes, but the nut is COMPLTELY stripped.what once was hexed is now completely round.cant even get a grip on the outside of the nut.how do i loosen it up enough to remove it?
Post by wolf on Jul 20, 2005 14:57:21 GMT -5
How about using a Dremel™ to put a notch or a slot in it so that it can be turned with a socket or a screwdriver, etc ?
damian
Post by damian on Jul 20, 2005 18:17:50 GMT -5
get some epoxy and glue the closest allen wrench you can fit in the hole of the nut. Careful not to get any on the surounding surfaces and dont get any on the truss rod end if it is visible through the adjustment nut. Wait for it to completly dry. And work it out slowly should work. Good luck tell us how it went. Peace Damian
d34th4uall
Axeman Custom Axes
Post by d34th4uall on Jul 21, 2005 17:37:04 GMT -5
thanks. i'll try that.post results in a few days.
damian
Post by damian on Jul 22, 2005 10:06:11 GMT -5
Wait that was the type with an allen wrench adjustment wasnt it? If it is more like a bolt end the procedure would be a little different. Also this only works if this has the style of nut you can replace. Damian
d34th4uall
Axeman Custom Axes
Post by d34th4uall on Jul 22, 2005 13:21:40 GMT -5
yes, it did have an allen head, but grampa stripped it out attempting to adjust it. i think he tried to tighten it too much.i hope it comes out cause i'm nowhere near ready to remove and replace a fretboard.
d34th4uall
Axeman Custom Axes
Post by d34th4uall on Jul 24, 2005 11:05:13 GMT -5
gonna have to get a whole new neck. rod was siezed up. cracked the neck removing the truss, oops.
Post by wolf on Jul 24, 2005 18:16:59 GMT -5
d34th4uallThe important thing is that you tried. You took a chance. I devised a method (and wired a guitar) for litearally getting 94 sounds from a 3 humbucker guitar www.1728.com/guitar3.htmRecently, I felt that none of the possible sounds were that overwhelmingly different from anything I hadn't already discovered. So, I removed the fancy "94 sound" switching arrangement and installed a more conventional switching system. Yes, it was a lot of work installing it and then installing a new system but at least I gave it a try. Consider yourself a "GuitarNut".
damian
Post by damian on Jul 24, 2005 23:01:38 GMT -5
Very true Wolf. I think that is the fun of doing it yourself. So much risk, life is to short not to just f it and give it a go. Unless it a priceless colectible guitar!! Peace Damian
d34th4uall
Axeman Custom Axes
Post by d34th4uall on Jul 27, 2005 15:14:53 GMT -5
yeah, i chalk it up to experience. it wasn't like it really beat it up anymore than grampa did(hahaha).we used the oppurtunity to remove the fretboard as well.why worry bout breaking it more if its already pretty much ruined.that proved easier than we thought. at least we didn't have to try it on something we didn't want to break. later
Post by jdtogo on Jul 28, 2005 17:53:21 GMT -5
ok so you did the best you could ! thats cool . so how you need a neck . you may try looking in pawn shops for a old guitar with a good neck . or ebay
d34th4uall
Axeman Custom Axes
Post by d34th4uall on Jul 29, 2005 15:12:09 GMT -5
i think i'm gonna get him a new guitar altogether. the body is pretty messed up, and i'm not sure putting a new neck on will even work. aparantly the original neck was broke by one of my cousins.whoever replaced it tore the body up doing the job.to my limited recollection, acoustic guitars don't normally have a bolt-on neck.
