Post by Ripper on Feb 11, 2006 23:59:56 GMT -5
I just watched a video of Seymour Duncan installing new pups...He mentions wiring in series or parallel. What in a nutshell does that mean? [glow=red,2,300]* Bracing for nutshell jokes*[/glow]
bjg
Post by bjg on Feb 12, 2006 0:37:03 GMT -5
Post by Mini-Strat_Maine on Feb 12, 2006 6:32:29 GMT -5
I just watched a video of Seymour Duncan installing new pups...He mentions wiring in series or parallel. What in a nutshell does that mean? You can wire two or more pickups in series or parallel with each other, and you can even wire the two coils of a humbucker in series or parallel, for different tone. Two pages that explain it very well: and www.1728.com/guitar.htm. Peanut shells are easy to open, but they tend to shred. Walnut shells are harder to crack, but if opened carefully, can be glued back together with the requested information inside. (If you hadn't said anything about nutshell jokes, I'd have let it slide, but . . . ;D )
Post by UnklMickey on Feb 13, 2006 20:21:20 GMT -5
[glow=red,2,300]* Bracing for nutshell jokes*[/glow] a nutshell is the outer covering of a nut. it's also known as a scr _ _ _ _.......as a scr _ _ _ _......as a scratchy thing. ...(If you hadn't said anything about nutshell jokes, I'd have let it slide, but . . . ;D ) unlike Doug, unk don't pass up no funny if he see's it. invitation or not.
Post by wolf on Feb 13, 2006 23:22:58 GMT -5
Well I was all set for posting explanations and / or links but I see that several Guitar Nuts have preceded me. Thanks folks.
