Post by lawrencedesigns on Jun 25, 2006 10:44:02 GMT -5
I've recently stole a Markley transducer pup on eBAY. Another toy to play with. The adhesive on it was essentially gone. I have tried Earthquake paste (we have a lot of that here in L.A.) but it doesn't do the trick. Any ideas?
Keeth Lawrence
Post by RandomHero on Jun 26, 2006 19:17:39 GMT -5
A form of epoxy or anything that dries rock solid will be best.
Post by sumgai on Jun 27, 2006 14:02:25 GMT -5
A form of epoxy or anything that dries rock solid will be best. Except that you won't be able to remove the pup in the future, should it need service, or if you merely decide to re-position it. More to the point, if you secure it this hard to the body, then it will not only sense the strings, it will also react to the body's vibrations. That could lead to ugly cross-talk, or it could be a nice chorus-like effect, but why take chances, eh? Unless there is a very shallow depth for the pickup, then you should be able to use double-sided tape. There are thin and thick tapes, so you should be able to find something that will suit your needs. HTH sumgai
Post by lawrencedesigns on Jul 8, 2006 9:19:05 GMT -5
Sumgai, You are right. I move this pup from my acoustic, to the 12 string, to the mando, to the dulcimer, blah blah blah That is the ENTIRE point of this type of pup. I have tried double face, but it doesn't seem to hold. Interestingly, I have written twice to Dean Markley on their website info request form. Not even a courteous "Go Away!" or anything from them. I think I am about to give up...
Keeth Lawrence
Post by sumgai on Jul 8, 2006 17:50:35 GMT -5
Keeth, I don't know where you get your tape, but the stuff I got ahold of was meant for holding down carpet. I have to cut it with a knife to make it let go! But the other side of your problem is that you 'want' portability. In that case, you need a low-tack adhesive, but finding one that defies gravity (the mounting surfaces are vertical), yet releases the pup without a fight - that's gonna be a tall order, partner. Perhaps Runewalker has something for us here. Hey, Rune, can you please show Keeth what's behind Door Number 2? sumgai
Post by lawrencedesigns on Jul 8, 2006 18:37:06 GMT -5
Sumgai, I KNOW what is behind Door 2. But then, I've been a camera operator on The Price Is Right for almost 30 years... But seriously, thanks for the response. Whatever the magic formula that was on it originally is what I need, but like I said, Dean Markley ain't talking.... I'll just keep hitting Lowes and Home Depot buying assorted sticky things... I have quite a colllection now..anyone need something stuck?
Keeth
Post by TooManyWires on Jul 11, 2006 20:04:44 GMT -5
It'd probably leave some residue, but certain kinds of sticky tack might work? Having used it all over walls this past year in residence, I can say that it does leave residue, but it comes off pretty easy. Like, a damp rag usually does it, or often enough even just using the big ball of sticky tack to pull it off with. I dont know, if you haven't already tried it, it might be worth a shot..
Post by lawrencedesigns on Jul 11, 2006 22:27:13 GMT -5
"Sticky tack" is not an adhesive I have heard of or run into...but it certainly is worth a try.. Local hardware or big box hardware store perhaps?
Keeth Lawrence
Post by bam on Jul 11, 2006 23:35:19 GMT -5
I use sticky tacks. To be more precise, the ones that kindergarten kids uses for their crafts. A small bit of advice: don't use too much, as it absorbs vibration.
Post by TooManyWires on Jul 12, 2006 15:12:16 GMT -5
I use sticky tacks. To be more precise, the ones that kindergarten kids uses for their crafts. A small bit of advice: don't use too much, as it absorbs vibration. Yeah, that would be an issue. I've never tried it for this application, I just use it for holding posters to walls. We aren't allowed to put tacks in the walls in residence. So we use sticky tack. It's like....blue stuff that looks like clay when you start, then you tear little hunks of it off the stick and make them into wads and they're sticky and stuff. You should be able to get it at places that sell office supplies, like Staples, or anywhere you'd find school supplies, and potentially in hardware stores too.
Post by lawrencedesigns on Jul 12, 2006 19:22:20 GMT -5
Thanks all! I found it! Elmers Tac 'N Stik. It has held on my 12 string for a couple of hours now...Just a thin strip...sounds great. Thanks again.
Keeth
