famreun
Post by famreun on Jun 27, 2006 16:16:28 GMT -5
Hi, seems like you guys really know your stuff. I have a cheapo guitar that a friend gave to me its a strat copy, it says Lotus on it, not sure if fender makes it or what. Anyways I am rebuilding it. I am not sure what are some good pickups, i hear that some good names are duncan, GFS and EMG. I play all different kinds of music, mostly rock though. I just want something that sounds really good all around. What kind of combo would you recomend? I was thinking of a GFS Vintage Alnico Tele pickup for the neck and a Seymour Duncan SPH90-1n Phat Cat pickup for the bridge. Any suggestions? dont have to worry about how they will fit into the body, any shape or size I can make fit. THanks!
wesman
Post by wesman on Jul 2, 2006 9:01:46 GMT -5
If you've never tried modifying a guitar it would be easier to get pickups that are a direct replacement.
The GFS stuff has good bang for the buck, Try sticking with one pickup manufacturer, to avoid polarity/ phasing issues.
Good luck with your project, Wesman
Post by dunkelfalke on Jul 2, 2006 12:56:09 GMT -5
if it is really a strat copy it might be that a tele pickup won't fit. anyway, you might as well stick with gfs, they also sell humbucker size p90s (dream90)
Post by vonFrenchie on Aug 8, 2006 18:56:04 GMT -5
I must say GFS does have a fairly impressive selection. But a neck telecaster pickup should fit in any position in a strat style guitar. Also (since its a strat) you can rout out a "pool" cavity, which is a rectangle the width of the pickups that stretches from the bridge pickup to the neck pickup. You could put almost any pickup in a rout like that.
Post by sumgai on Aug 9, 2006 1:48:49 GMT -5
vF, Actually, your description of routing out a giant area around all three pickups is properly called "universal". "Pool", or "swimming pool", refers to a route that encompasses only the Neck and Mid pups, the Bridge pup route being left in a stock state. (Don't ask me why they'd do that, but there you have it.) For reference, I've quoted a couple of images (and their captions) from the USA Custom Guitars website....... Universal pickup routing available for top routed guitars. 'Swimming-pool' routs available for universal pickup configurations. Warmoth has almost the exact same thing, nearly verbatim. HTH! sumgai
Post by vonFrenchie on Aug 9, 2006 13:45:29 GMT -5
From all the pool pictures I saw it looked like the neck pickup was included. Obviously its not.
Post by ChrisK on Aug 9, 2006 14:45:59 GMT -5
In a pool route, the neck pickup IS included. On a Tele pool route, the bridge is not "in the water". I actually use my MIM Nash Power Tele as a pickup tester w/ 1" x 1" x 2" foam blocks for positioning. The TeleToggleCaster A Tele neck pickup will fit into the physical space of a Strat pickup, but the pickguard hole and the mounting screw spacing are smaller. I AM NOT a fan of pool routes on a vibrato (sorry Leo) equipped guitar since most of the "beef" in the middle isn't (anymore). Many (as in both of mine) Am Strats are routed HSH anyway.
Post by ChrisK on Aug 11, 2006 13:01:25 GMT -5
Oh, as far as to which pickups to get, I ended up getting most of them!
