Post by RandomHero on Oct 5, 2006 18:47:07 GMT -5
I just found another one on accident. Palm harmonics!
-Lightly- "mute" the strings while picking around the realm of the 24th fret and on. You can harmonic entire chords if you're in the neighborhood of any of the sweet spots for each string...
Got any unique/unconventional ways to share with us?
Post by UnklMickey on Oct 5, 2006 19:27:18 GMT -5
The many ways to make a string squeal...
hmmmm ....................... sounds like a description of a Ted concert!
so, that's like the edge of your palm, between the base of your little finger and your wrist?
Post by RandomHero on Oct 6, 2006 8:00:25 GMT -5
Yep. Just leave it there lightly until you pick, then let off. It responds best in higher gain situations, of course, because it's fairly faint. Most of the time I've done it I get anywhere between a trace to about 50/50 of the fundamental still sounding through, which is a pleasing sound to my ears.
Post by UnklMickey on Oct 6, 2006 11:59:09 GMT -5
definitely sounds like somethin' i'll wanna try.
i don't usually play with high gain, though
i do think i could us it, to make them chords sound purdy, though.
i do something now, that's related, but implemented differently.
i drag my thumb behind the pick, as you would with a pinch harmonic.
but i don't dig in quite as deep.
as i play a chord, even if i am picking where i can't produce a strong harmonic,
the slight muting by the thumb, completely changes the structure of the tone.
sorta 'chimey'.
i'll hafta try it your way,
i might even me able to combine that with finger plucking.
Post by ranchtooth on Oct 10, 2006 20:03:48 GMT -5
I get some good squeals by using a nickel as a pick with the gain cranked.
Post by UnklMickey on Oct 11, 2006 20:05:39 GMT -5
if you're in the great white north, and use one of those old (pre '42) nickel nickels, you could prolly get some pretty serious thumps along with those squeals.
Post by johan on Oct 14, 2006 8:12:53 GMT -5
if i understand this correctly is just a flageolet on a fretted string? but then i'm in doubt beause i do this all over the fingerboard. how about a video demo?
you just let the string hit your thumb after the pick, so you hold the pick in such a way that the part sticking out from between your fingers is as small as possible. and true true, harder picks work better for this...
j
Post by UnklMickey on Oct 16, 2006 14:00:21 GMT -5
hi Johan,
that describes what i'm doing. (btw, i just use a run-of-the-mill Fender heavy.)
but if you read carefully, RH has an entirely different slant on this.
mmray321
Post by mmray321 on Nov 30, 2006 20:22:27 GMT -5
hey guys,first off i play bass,when i do harmonics i lay my thumb down in front of my index finger,pick and right after i just let my thumb off,i think this is called"pinching?". whell i saw how victor wooten does his,it looks way EZer,but i cant figure out what he's doin
Post by ranchtooth on Nov 30, 2006 20:37:26 GMT -5
I think he just uses his fingernails to hit the harmonic while using a very light touch with the left hand... thats how I do my ripoff of amazing grace via bass harmonics.
mmray321
Post by mmray321 on Dec 8, 2006 21:19:24 GMT -5
i got it,but its kinda wierd how it is,like u gotta throw it way outa tune to play sumthin
