Post by jmartyg on Feb 24, 2008 2:06:21 GMT -5
cemetery gates.. the main riff. It's all fretted and the harmonic is done with the thumb and pick with the picking hand. I just dont know what the termonology is. So when i show people, i don't want to use my own words for this and confuse them more.
here is the tab from the top of my head:
D|---------------------8~------- A|--------7-5-7-7~-5-7----5-7~-- E|--0-0-0-----------------------
~ = bend
clr
Post by clr on Feb 24, 2008 2:38:58 GMT -5
Pinch harmonic
Post by sumgai on Feb 24, 2008 3:09:01 GMT -5
j, You'll also sometimes see it called an 'artificial harmonic'. Technically speaking, it's a natural harmonic, all subdivisions of a fundamental frequencies are harmonically related. But in this case, you dampen the string with your thumb before some of those harmonics have time to build in volume level. This creates a new harmonic relationship that you can easily hear, which sounds a lot like a second or third overtone harmonic (natural harmonics found at the first and second octave points). Like 'pinching', 'artificial' isn't really a good name for what's happening, but either one will convey your meaning well enough. HTH sumgai
Post by jmartyg on Feb 24, 2008 17:10:59 GMT -5
Thanks guys!
clr
Post by clr on Feb 24, 2008 17:36:07 GMT -5
Well, sometimes its referred to as a Squeelie, I Think thats accurate But pinch harmonic sounds so much more cooler
Post by sumgai on Feb 24, 2008 19:09:09 GMT -5
But pinch harmonic sounds so much more cooler Like when you're "Pinching For Some Tush"? ;D
Post by jmartyg on Feb 24, 2008 20:56:01 GMT -5
oh, in case anyone is wondering, the font that is evenley spaced is called 'fixedsys'
