Post by mlrpa on Jun 25, 2007 20:08:30 GMT -5
Like I said earlier, I don't care for black, so sometimes, when the mood strikes I refinish. Here are a couple of examples. Yea, I know, ugly. But bulldog ugly, which is cool! It's a mid 80's Lotus neck thru, with the original MK45 Matsumoku pickups, and the factory phase switch. Now if I can remember to get rid of those stupid plastic knobs.... 1990 Ibanez S540. How dare they cover that mahogany with black paint!!! Birdge pckup is a Ibanez INF4, and just ooozes warmth! a 1985 Westone Dimension IV. All orginal, except for the finish of course. The push/pull knobs are coil tap, mid pickup on, and phase. She's GREAT for doing jazz chords on! And of course, how many black Mockingbirds have you seen? This is done is a purple pearl swirl, stained a bit darker fretboard, with Duncan clone pickups. Actually sounds kinda sweet.
Post by quarry on Jun 27, 2007 15:22:44 GMT -5
Here's the same picture I posted in "Post Your Black Guitar" thread... The one on the far left is an old Peavey Raptor. It started off all black. I sanded it down, stained it Red Oak, and added the faux burst finish with a spray can of black lacquer...
jorg
Post by jorg on Sept 25, 2007 12:47:43 GMT -5
Hey mlrpa, That Lotus has original MMK45's? Was it made by Matsumoku?
Jorg
Post by mlrpa on Dec 21, 2007 11:58:32 GMT -5
YEP! Most Lotus' in the 80's were made by Uncle Matt.
jorg
Post by jorg on Jan 3, 2008 11:32:30 GMT -5
I'm a big fan of Uncle Matt guitars. I don't think I've had any 45's though. My current favorite is a PE-R60 with MMK53's. ;D
Post by lpf3 on May 4, 2008 19:00:28 GMT -5
Hi , guys , Been tryin to post a picture all afternoon...... Just checkin' to see if it works lpf3
Post by lpf3 on May 4, 2008 19:18:40 GMT -5
Oooo-k Help , I logged in to photobucket , uploaded my pic's & followed ( I think ) both sumgai's & randomhero's instructions for posting pictures . I used the http adress I got from photobucket..... What now ? lpf3
Post by newey on May 4, 2008 21:34:47 GMT -5
lpf-
Did you use the img tags? It's the last choice listed to the right of your photo on photobucket. Just copy and paste into your post. Preview it to double check.
Post by ChrisK on May 5, 2008 0:05:29 GMT -5
lpf3
While your link links to your photobucket account, it does NOT include a file name.
{img]http://s293.photobucket.com/albums/mm43/lpf3guitars/[/img]}
{img]http://s293.photobucket.com/albums/mm43/lpf3guitars/filename.ext[/img]}
({ is really [ and } is really ].)
Under each picture there are four address boxes. Use the lowest one.
Go to the photobucket folder that contains the picture:
Right click on the "IMG Code" field under the picture:
Hit "Ctrl C" (copy)
Go to your post (while you're editing it), position the cursor where you want the link, and hit "Ctrl V" (paste).
This is easier if you use two browser instances.
Post by lpf3 on May 5, 2008 18:24:49 GMT -5
ChrisK- Thanks ,( as usual ) I had made it harder than it had to be , I guess....... Anyway , here goes......... I wish I had before pic's - it didn't look bad at all in black , maybe a little "uptown " for my taste . For the color I mixed a little amber shellac in my lacquer.... ...went over that with clear . The electronics are pretty simple - Stew-Mac Golden Age HB's , the front 2 knobs are push-pull pots for coil tap on each pup , as well as master vol. & master tone . The back 2 knobs are " dummies " just there to fill holes . The original 'guard is black , I made this one out of a Warmoth blank . Next time I change strings I'll make a bone nut & that's it , I'm done . 'Bout time , too , I've been workin' on this way too long....it was a lot of fun but I'm sooooo glad to be finished . I oughta plus 1 the whole forum for all the help , both directly & indirectly ........... thanks much , guys . -lpf3 ,
Post by ChrisK on May 5, 2008 20:36:52 GMT -5
I'm glad that the posting worked out.
That is a mighty nice guitar.
Post by newey on May 5, 2008 23:05:37 GMT -5
lpf- Very nice, but what is it? I can't make out the logo on the headstock.
Nice refinishing job, too, looks well done.
Post by lpf3 on May 6, 2008 9:16:58 GMT -5
newey- It's an Ibanez Artstar . I don't know how old it is , my son gave it to me as a birthday present & he bought it used . Thanks , actually it was a tough job.....twice I decided I didn't like it & washed it all off with steel wool & lacquer thinner More than once I thought , next time I want a certain color I'll just buy one .....but then I wouldn't be a Nut , would I ? Here's one of the colors I didn't like ( messy garage & all lpf3
Post by lpf3 on May 6, 2008 12:19:52 GMT -5
ChrisK - Thanks , I really like it . Also for the posting help - I just learned how to resize my pic' s , hope that's better . -lpf3
Post by Teleblooz on Jan 22, 2010 12:08:13 GMT -5
Kramer XKB-20 Bass It used to be black. Then it was white, splattered with yellow & blue. Then I got sick of looking at it. Now it's back to its original finish with a layer of grunge sanded off, looking better than it ever did when I first got it.
Post by ux4484 on Jan 22, 2010 12:15:08 GMT -5
Wow... an actual thumb rest above the strings...not very common...did you add it?
steveb
Post by steveb on Mar 12, 2010 14:25:31 GMT -5
My '62 Jazzmaster was originally Dakota Red, but it got sprayed Chartreuse and then black over top of that by the previous owners before I bought it in '77. The different paints reacted with each other and the finish was cracked and flaking. One day in the early '80s I got fed up with it, stripped it off and re-finished it clear with a little bit of light stain.
Post by Teleblooz on Apr 20, 2010 14:00:13 GMT -5
Wow... an actual thumb rest above the strings...not very common...did you add it? Yes I did. For some reason I always liked those things (and putting it on the treble side always seemed absolutely useless to me).
Post by ijustwannastrat on Apr 20, 2010 15:15:38 GMT -5
Thumbrest on the treble side sounds like bass ala Paul McCartney.
He's the only person I really ever noticed playing with their thumb.
Then again, he's really a guitarist.
Then again, again, he was dead this entire time, so it's a wash.
