Post by D2o on May 20, 2008 13:13:58 GMT -5
I will check the Ohms next time I have the strings off, but I doubt it will be a problem. CYF, You don't need the strings off, just do a little scan through the nostrils, per ChrisK's excellent tutorial. Set the multimeter to 20k ohms and you can get a reading right off the patch cord. guitarnuts2.proboards45.com/index.cgi?board=reference&action=display&thread=3186I hope that helps. EDIT - my apologies, you are talking specifically about the tape here ... I didn't catch that context the first time I read your last post. You cannot measure the continuity of the shielding with that method, but keep the link above in your back pocket as a useful tool. Sorry if I caused any confusion.
Post by ChrisK on May 20, 2008 20:27:31 GMT -5
So, the shielding is not elementary Master Ohms, but it's BLEEPIN' good anyway?
(Most of the BLEEPIN' Ohm meters work this way. For continuity testing, one doesn't want to take one's eyes off the equipment, but for Ohms, one must.)
