lonestar
Post by lonestar on Jul 14, 2008 8:43:41 GMT -5
Hello,I am new here and I was wondering if someone had a wiring diagram for wiring a um in the bridge,single coil in the neck with one volume and no tone with a 3 way switch?I have seen this wiring on several Charvel guitars.Thanks ahead time for any help.
Post by pete12345 on Jul 14, 2008 8:59:56 GMT -5
Assuming you want the three positions to be neck, bridge+neck (parallel), bridge, just follow the wiring for a telecaster style guitar, leaving out the tone control.
Alternatively, you have three coils in your setup (think of a strat with the middle coil pushed towards the bridge) so you could investigate some of the setups intended for strats. This is only really an option if your bridge humbucker has four wires rather than two.
Pete
lonestar
Post by lonestar on Jul 14, 2008 9:02:19 GMT -5
Thanks for the info.Yes,my humbucker has two wires.
Post by pete12345 on Jul 14, 2008 10:58:21 GMT -5
Hmm... that would leave you pretty much stuck with tele-style wiring schemes then. I'm personally not too keen on five way switches, but if you used a five way superswitch rather than a three way (they fit in the same slot), you could get some interesting series, parallel and out of phase combinations as well. Have a look at the T-riffic diagram on the main site.
Pete
