Post by hembryguitars on Oct 29, 2008 20:23:37 GMT -5
I just need a quick wiring diagram. I'm surprised someone hasn't posted one of these in the schematics section.
A customer wants his 5 way to give him these choices:
1= n 2= n+m 3= n+b 4= b+m 5= b
The only difference from a stock 5 way wiring is the middle position being a combination of the neck and bridge. I think I might have to use a superswitch and that's fine with me. If someone could help me out, it would be greatly appreciated.
Post by ashcatlt on Oct 29, 2008 22:36:15 GMT -5
Welcome.
It can't be done with a standard 5-way.
Is it standard strat 1V 2T?
You gonna share the comission?
Edit - no it can't, fixed!
Post by hembryguitars on Oct 29, 2008 23:30:29 GMT -5
I was pretty sure it couldn't be done with any of the standard 5 ways.
It's not a standard strat (1v 2t) It's easiest to think of it as three singles going to a single volume.
What it actually has in it is a nightmare. Humbucker sustainer in the neck, Seymour single in the middle, Joe Barden hum in the bridge, Graphtech piezos in the saddles, a coil tap for the Sustainer and Barden and seperate outputs for the piezos and magnetics.
I would love a diagram for three singles and a 5 way with the switching options:
I would love to share the commission but I've used it all up in the time it took me to make everything else work. It works fine the way it is with the fraditonal 5 way selecting but he just thought of making it have the other switching option. I told him I'd give it a shot but my electronical mind is shot right now so I can't even imagine figuring out the super switch wiring.
Post by pete12345 on Oct 30, 2008 3:32:29 GMT -5
Would you take series wiring for the middle position? If so there's a diagram on the main site for that with a standard switch. If not you'll need a superswitch
Pete
Post by hembryguitars on Oct 30, 2008 3:43:02 GMT -5
I think, for what the customer is going for, it would be too hot.
Post by JohnH on Oct 30, 2008 6:23:56 GMT -5
How about a little text art? Bo o---o---o o o o o o o o o not used ! ____________________________________________out ! ! ! ! No o o o---o---o o o o o o oM
OK, bad idea, that was very fiddly to draw, but the switch wiring is OK. All pup grounds go to ground as usual. Three out of four poles of a superswitch are used as above, with one pole each for N, M, and B hots as shown. cheers John
Post by ChrisK on Oct 30, 2008 11:17:03 GMT -5
Post by ChrisK on Oct 30, 2008 11:38:02 GMT -5
Actually, you only need two poles of a super switch (the semi-super switch).
Both pole commons go to OUT
Pole 1 1. N 2. N 3. N 4. M 5.
Pole 1 1. 2. M 3. B 4. B 5. B
Post by hembryguitars on Oct 30, 2008 15:05:09 GMT -5
Right on! Thanks guys. This isn't my first time here getting saved by you all. Oh, and I have had a link to this site and the original site for quite awhile now. I'm not here a lot, but I do appreciate and spread the word! Here both are on my links page in the lefthand column: www.hembryguitars.com/links.htm
Post by hembryguitars on Oct 30, 2008 15:15:37 GMT -5
Here's the guitar this is going into:
Post by newey on Oct 30, 2008 18:51:59 GMT -5
We've got a link to Hembry Guitars on the "Links Page- Sort of". I just added the info that you're a member.
Post by JohnH on Oct 30, 2008 19:51:45 GMT -5
Now you have two ways to wire up the superswitch, and Chris’ is more minimalist. I would suggest not admitting to your client that half the switch is unused however. Otherwise he’ll ask for additional satellite navigation with pup-up toaster!
Post by hembryguitars on Oct 30, 2008 22:49:32 GMT -5
I love Chris's minimalist solution. I like as clean a control cavity as possible and this one is a nightmare already with the two cicuit boards and all of the wiring that comes with them. I apologize if the pic I posted was too racy. I wasn't sure if it would fly. Here is a more appropriate one: Again, sorry about that.
Post by newey on Oct 31, 2008 5:21:41 GMT -5
Nice looking guitar! And no chance of "buckle rash" with all the extra rear routing! ;D
Post by ChrisK on Oct 31, 2008 19:11:24 GMT -5
You are all "minimally" missing my point! Unless you have a super switch and don't want to buy the MegaSwitch "E", The "E" Model Megaswitch .....and the technical info therefor.IS the minimalist solution. (And, the Schaller MegaSwitch mechanism has the best mechanical design and feel of ANY lever switch ever developed.) It just might not have a Tele top hat tip for it.
Post by hembryguitars on Nov 1, 2008 2:50:02 GMT -5
Oh geez. I'm a spaz. I totally forgot I bought a fistfull of these 5 ways from AllParts a while ago. Part# EP 0479-000. They are basically half of a SuperSwitch. They are pretty cool and work perfectly for what I wanted it to do and Chis's diagram will work perfectly. Again, thank you. Here's a link to the switch: www.allparts.com/store/electronics-switches-ep-0479-000,Product.asp
