Post by Happyguy on Feb 13, 2009 22:20:51 GMT -5
Hi again, I'm in the midst of implementing JH jimmy page design. Everything is going fine. I noticed that the main 3 way switch is grounded and that the others are not. Is there a reason for this? Or does this mod take into account that we all have foil in our geetars to ground everything? If i do not have foil in my guitar should i go ahead and ground the switches like this? Thank you in advance!
Post by ChrisK on Feb 13, 2009 23:23:34 GMT -5
Yes, the switch cavity is rarely shielded.
Yes, see above.
Yes, probably, I can't make out all of the connections and my eyes are tired.
Post by JohnH on Feb 14, 2009 6:19:21 GMT -5
Agreed - if there's no shielding or Gibson ground plate to ground the pots, your extra black wires will help a bit.
I do think that grounded cavity shielding would be helpful here though, more so than on a standard LP wiring. It will work without however.
Note that the new black wire going to S2, is almost the same connection as a green wire going to the adjacent switch lug top right of switch S2. You can save a wire by just connecting this already grounded lug to the switch case.
Post by Happyguy on Feb 15, 2009 21:36:03 GMT -5
Understood I bit the bullet and the guitar is now shielded and star grounded... what a tedious process. Thank you again, remains to be seen if all will work as intended.
