Using On/On 4PDT toggle for S-1 Feb 26, 2009 14:28:25 GMT -5 Reply Quote Select PostDeselect PostLink to PostMemberGive GiftBack to Top Post by xero27 on Feb 26, 2009 14:28:25 GMT -5 I don't like tone knobs, I never use them.If I ditch one, or both, tone knobs can I put in an On/On 4DPT toggle to function as the S-1 button does on the S-1 Strat?Like this one:www.allelectronics.com/make-a-store/item/STS-70/4PDT-ON-ON-TOGGLE-SWITCH/-/1.html
Using On/On 4PDT toggle for S-1 Feb 26, 2009 16:59:50 GMT -5 Reply Quote Select PostDeselect PostLink to PostMemberGive GiftBack to Top Post by ChrisK on Feb 26, 2009 16:59:50 GMT -5 Well, since the S-1 IS a 4DPT switch, uh, yeah!The switch that you linked to IS NOT acceptable. It is for switching large currents and may not have its contacts kept clean (free of oxidation) by the minuscule currents in play in passive guitar pickup circuitry.Here are some switches. I prefer the 0.4 VA switches since these ARE rated for dry contact (really low as in down to zero, signal current);search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=1004P1T8B13M2RE-NDspec.e-switch.com/T-D/T112027B.pdfsearch.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=360-1872-NDAlso, one often finds S-1 pot/switch combos for sale on ebay.
