Post by angelodp on May 23, 2009 20:31:57 GMT -5
When does it make sense to use a revers audio taper pot for Tone in a guitar.
ange
Post by newey on May 23, 2009 20:51:50 GMT -5
For southpaw guitars, primarily.
Post by ChrisK on May 23, 2009 22:08:53 GMT -5
If you are using a pot to blend in another pickup in parallel, a reverse taper pot makes this much more usable. In this case, full blend-in occurs gradually up to "10". Using a regular audio taper pot, for reasonable gradual blending, requires the pot to be wired in backwards, with full blend-in occurring at "0". If you can't find a reverse taper pot, think and look again. After all, a blend Pan pot is both a normal taper and a reverse taper element on the same shaft.
