Post by angelodp on Jun 26, 2009 21:28:03 GMT -5
In this SD auto-split position, 4 on the 5-way is set to short the screw coil so that the slug is HB with the middle pickup. So I presume that by swapping the pairs of wires ( black green with red white) the screw coil would be selected for HB with the M pickup. Question. Can I run an spst switch for the neck on as per the usual method and then have the option for N+ B .
Post by JohnH on Jun 27, 2009 20:20:11 GMT -5
I don't see why not, to connect neck white direct to volume pot hot.
