Another couple of points to ponder......
In that other thread, I jacked around with RJB, and upon re-reading it, I realize that all of us failed to mention the real culprit here, the wattage ratings.
In essence, when a manufacturer quotes a rating, that number is worthless without some sort of reference point. In this case, as newey as alluded to above, it's the wattage at some distortion level, as measured with a steady-state input - it doesn't vary over time, so the output shouldn't either. This is, usually, the RMS value. It can be diddled with, but in general, if a company says "XYZ watts RMS at so-many ohms", you can probably rely on that figure.
Note though, that nothing was mentioned about distortion. This is notoriously hard to pin down, and not because it's subjective. In fact, there are at least 4 kinds of distortion I can name off the top of my head, and some of my synapses fired a moment ago, trying to tell me that there are more than a dozen kinds. Sadly, I can't even start to remember their names, and I perceive that it doesn't really matter, so I'm gonna go all lazy on ya, and not bother to Google for the answers to that non-burning question.
The bottom line for us is harmonic distortion. This is defined in various ways, but I like "when the amplifying device introduces harmonic artifacts that were not present in the original signal". How that happens is not germane to this topic, so we'll leave it at that. But the fact is, if you apply too much operating power to a device, or if you apply too strong of an input signal to that device, then harmonic distortion will occur. Note: not
may, but
will occur. The only question left to answer is "how much of that distortion can a listener withstand?".
And that's also not really a concern for us.... we're after tone, and as everyone who's played an electric gutar for more than 10 minutes can tell you, an electric guitar
should sound distorted, or else it "doesn't sound very good at all". This is an "AHA!" moment folks, take note, please.
Now we're at a cross-roads of 'how much power' versus 'how much distortion' versus 'how much do we like the sound', aren't we? Well, if it's any consolation, newey's correct about the auto bit where distortion and hiss are of less concern (until you get to the real competitions, where they put your rig in a sound-proof booth and bring in all kinds of meters), but for reference, Leo started with the Williamson circuit straight out of the 1946 RCA Tube Reference Manual, which featured the "low distortion factor of only 5%"!!! You read that right, five percent was considered good enough, in the early post-war era.
Today, Fender, and most other amp companies, are down around 1%. This helps to explain why, after CBS bought the company in 1964 (and started monkeying with the engineering in 1965), the power ratings were reduced, even with almost the exact same power amp circuits. The distortion factor was factored into the equation, and the output rating was adjusted accordingly.
Now, getting back on topic.....
Not only does distortion play an integral part here, but actual power requirements do too. IOW, the power rating is for a steady-state input signal (aka RMS), but how often does that occur for a guitar player, eh? Not very, I'm inclined to answer. When we pick a string, even without a pick, just our skin, the attack transient is very sharp, and in order to reproduce that accurately, there needs to be a high amount of power delivery available. After that, the sustain portion of the signal (ADSR - look it up) takes over, and thats where we usually operate, about 95% of the time.
To boil it down, we really need, and use, only 2-5% of the total power of which our amps are capable. Only during the initial pick attack do we ever exceed that low power level. (Well, if you use echo, then the attack may occur repeatedly in quick succession, but you get my drift here.) For that, we have available, and may well use, all 50 watts or all 100 watts, or whatever.
But wait, what if we don't need "clean" sound during the pick attack, can't we just use a smaller-wattage amp? Sure can, Homer. However, the problems that arise from that are real gotchas. First, we need to worry about the speakers and how they respond to distortion products from the power amp. Ooooh, let's stop right there, that's a headache all by itself. No, better to keep things matched up as known, accepted, and mostly loved, by the whole industry. Are we cool with that, Jethro?
Nitty gritty time....
Long story short, you can tap a 1200 watt amp for duty, but you really should read the fine print first. Is that rating in RMS watts? And at what distortion level, please? And of course, at what output impedance. (As an aside, did you know that Bose now makes a new line of LifeStyle speakers called the LM-48, which needs it's own special Bose-made amplifier? They operate at
0.75Ω of impedance, something that would absolutely guarantee a steady income for fuse makers, if you tried hooking them up to any "normal" power amp. 'Struth!)
Bottom line.....
In short, power is cheap, good clean power is not. And that's before we start talking about reliability, size and weight, connectivity, etc.
But hey, experiment away.... Who am I to fly in the face of the next Lee de Forest?!
p.s.
ash,
I don't know your/the band's budget, but I picked up a cheap QSC RMX850 for $150 off of craigslist. That and eBay should be your top Bookmarks/Favorites, until you finally get what you need/want. Just a thought.
