snbrst
Post by snbrst on Aug 30, 2009 15:56:15 GMT -5
Hi guys & girls (to be PC), You wiring wizards have come highly recommended and I just registered today to ask this question as I can't find any diagrams to do this (maybe too simple?). I have a normal stock Squire Strat. Can I. by just moving wires. get a Neck & Bridge (Tele) on middle position 3 and have all the other STOCK positions/combinations remain the same as stock? I have been told it's doable but how? I know with an added switch it's the 7 way mod and I have seen the FREE neck switch diagram but I'd prefer to do it w/just the stock 5 way switch and I may go to a master vol & master tone also. thanks in advance for any help...even a NO it won't work would ease my mind at this point!
Post by sumgai on Aug 30, 2009 17:49:46 GMT -5
snny, Hi, and to the NutzHouse! You've pretty much already answered your own question - you can indeed swap the Middle pickup's wire with the Neck's wire on the 5-way switch, and when you select the 2nd position, you'll get Bridge in parallel with Neck. (Here, position numbering starts as 1 is the Bridge pup.) Conversely, you can swap the Bridge and Middle wires, and the magic combo will show up in position #4 instead. Just keep in mind that you're in good company - Sagans of modders have done this since the dawn of the Stratocaster, in order to get "that" Tele tone. Good luck! HTH sumgai
snbrst
Post by snbrst on Aug 30, 2009 21:38:39 GMT -5
Thank you for the welcome Sumgai. I have in fact swapped the pickups and or wiring in strats BUT, I'm looking for the tele combo to be in the nbr. 3 (middle of the 5 way) position AND keep the other 4 positions the same combos as STOCK. That's the part that's got me crazy
Post by newey on Aug 30, 2009 21:56:14 GMT -5
Sunny-
Hello and Welcome!
Bound to drive you crazy. In order to get B+N in pos. 3, this means at the very least that the mid pup cannot also be wired there. And if the mid cannot be wired there, then pos. 2 and pos. 4 are going to change as a matter of course, due to the nature of the std "5-way" lever switch.
A superswitch would do the trick.
Most who want N+B get there via the alternative route of having a neck (or bridge) "on switch", which also then gives one the "all 3 pups" option (desirable, IMO).
Post by JohnH on Aug 30, 2009 22:02:09 GMT -5
I agree with newey - it cant be done with a standard 5-way, and a 4 pole superswitch could do it. But also, you could get one of these megaswitches, E-type, which are specically designed for this combination: www.stewmac.com/shop/Electronics,_pickups/Components:_Switches_and_knobs/1/Megaswitches.html Its simpler than a superswitch John
snbrst
Post by snbrst on Aug 30, 2009 22:15:14 GMT -5
Thank you all. I was hoping that wasn't the answer but I was thinking it was. But at least I'm not a moron...unless you ask my wife! snbrst
