stratlad
Post by stratlad on Jan 15, 2010 15:59:03 GMT -5
Hi all great forum btw, ;D I've just done a mod on my usa strat plus called a blend mod and if i select the bridge pick up i can use the bottom tone control to blend in the neck pick up with the bridge pickup it works and sounds great to me, but this only works on the bridge pick up and i wondered if it would be possible to add the mod to the neck pickup as well so if i select neck pickup i can bring in the bridge pickup.
Post by D2o on Jan 15, 2010 16:12:59 GMT -5
Hi strat, and WELCOME to GN2! If I'm correctly getting your drift (guys - this is sounding like a " free neck on" type of deal, right?) it won't work on the bridge pickup because the bridge doesn't have a tone pot on you (more or less stock?) strat. Other than the neck blend, is your strat pretty much stock wiring? Cheers, D2o
Post by newey on Jan 15, 2010 16:40:30 GMT -5
Seems to me that if you can live without the mid pup tone control, you could move that pot to the bridge position on the 5-way (one lug over from where it's wired now), and the wire it just like the "free neck one" link shows for the neck (which I assume is what you've already done on the neck).
And. .
Hello and Welcome!
stratlad
Post by stratlad on Jan 16, 2010 8:28:52 GMT -5
Thanks for replies just to recap my strat works exactly as a standard wired strat but, bottom tone control is the blend control knob if i select bridge pup then turn blend knob downover 10 - 0 it blends in the neck pup with bridge, sounds great to me ;D i just wondered if i could rewire without losing any of the above so as it works on the neck pup and use same blend knob to bring in bridge pup i have a link to diagram showing which way it is currently wired, also i have an unused mini toggle switch currently not connected but fitted in the scratchplate may help with rewiring it cheers all img.photobucket.com/albums/v82/rfdee/wiring/strat-blender2.gif
Post by JohnH on Jan 16, 2010 14:04:51 GMT -5
One easy way to do this:
Take the wire from the centre lug of your blend pot and instead of connecting it to the tone pot, instead connect it to the bridge white wire where it joins the 5-way switch. Now if you select bridge, you can blend in the neck and if you select neck, you can blend in the bridge.
cheers
stratlad
Post by stratlad on Jan 17, 2010 8:39:19 GMT -5
Hi thanks for replies everyone i'm gonna rewire as suggested and see how it turns out, and i'll post back later this week cheers all..
stratlad
Post by stratlad on Jan 18, 2010 12:42:08 GMT -5
Hey John i rewired as you suggested it looked odd on paper but i can confirm it works you're a star mate ;D tones i can get now are unbelievable. cheers man
Post by D2o on Jan 18, 2010 12:55:11 GMT -5
Hey John i rewired as you suggested it looked odd on paper but i can confirm it works you're a star mate ;D tones i can get now are unbelievable. cheers man Ditto from me, John. I was also curious so I wired my '92 Peavey Predator as outlined - very nice! +1 D2o
Post by JohnH on Jan 18, 2010 16:35:35 GMT -5
Too easy!
That kind of mod, at no cost, has added the following to the standard palette of Strat features, as compared to stock wiring:
Two extra main sounds, being N+B and N+B+M Four extra blendable sounds, in positions 1, 2, 4 and 5, based on blending in part of either N or B with the standard combos Tne master tone control works on the bridge too, unlike standard Strat tone wiring.
Post by D2o on Jan 18, 2010 17:06:26 GMT -5
Yup - having tone control of the icepick bridge was a terrific bonus. D2o
