Post by treguiers on Feb 5, 2010 11:15:41 GMT -5
Sorry people, been away for a bit-Family and work stuff. Anyway, The normal strat wiring is that in position 2 and 4 the bridge-mid and the mid-neck are in parallel. Is there a way of wiring the mid pup to a push-pull so that one way it's as is and the other way it connects bridge-mid and the mid-neck in series?
As always, any nuggets of wisdom will be warmly welcomed.
Post by JohnH on Feb 5, 2010 16:00:57 GMT -5
Hi tg - theres a heap of schemes that add series wiring to guitars with three single coils, in the schematics section. Its not easy to just change positions 2 and 4 with 1, 3 and 5 unaltered, without fairly complex switching. But if you would like to keep the rest of the controls the same, and just add a push/pull, then the last diagram on the first post of this thread is very close and is a clever scheme indeed. S-none switchJohn
Post by treguiers on Mar 15, 2010 21:07:10 GMT -5
Thanks john. a very interesting design indeed
