Post by stratoholic on Mar 15, 2010 16:19:02 GMT -5
Hey all, All the wiring diagrams that I have looked over say to ground the to the volume pot. Does that mean only to the volume pot for a reason, or can it be to any pot? Does it really make a difference? Thanks
Post by ashcatlt on Mar 15, 2010 17:52:34 GMT -5
You can gather your "ground" wires anywhere you want. None of these are actually grounds until they get to the amp chassis, but they are all ultimately going to the same place.
You do want to ground the pot cases if possible for shielding purposes.
It's a good idea to try to avoid redundant ground paths - where you can get from one point to another via multiple routes (wire or foil or whatever) - though we have some question around here on how much of an issue those "ground loops" really are in the context of passive guitar electronics.
I personally avoid soldering to the back of any pot for practical purposes (didn't I just type that same sentence somewhere recently?) - it takes a powerful iron, a steady hand, nerves of steel, and (I think) a heaping dose of luck. Oh, and half of my guitars just plain don't have pots...
Post by stratoholic on Mar 15, 2010 19:56:00 GMT -5
Thanks for the response and clear explanation ashcatlt. I appreciate your help. So, are you wired direct to the output jack or to the volume minus the tones?
Post by ashcatlt on Mar 16, 2010 0:24:13 GMT -5
Neither of my strats have pots. They've been replaced by rotary switches. Eventually, everything goes straight to the jack.
