jpbracken
Post by jpbracken on Mar 15, 2010 19:42:37 GMT -5
This is the one I'm talking about. Which pot is which? Ie, which is neck/bridge tone/volume etc. I'm assuming it's laid out in the diagram so that as you look down into the guitar cavity it should look like that, but I just wanted to make sure. Cheers.
Post by JohnH on Mar 15, 2010 19:58:25 GMT -5
THe pots are laid out in the conventional way, and this is the view loooking at it from the back cover.
Neck Vol Neck Tone Bridge Vol Bridge Tone
Thanks for your interest
jpbracken
Post by jpbracken on Mar 15, 2010 20:08:37 GMT -5
Thanks a million. My push-push pots were becoming a bit unreliable so I'm downgrading a bit.
Post by JohnH on Mar 15, 2010 20:31:10 GMT -5
Great - I was going to do a big push/pull scheme, but found I really liked the solid simplicity of standard CTS pots. Ive added a bit more to this scheme, which might interest you - see this one: LP Modular wiringThe cavity wiring is very similar and does the same thing, but then it can extend to put more functionality, such as series and phase into the switch cavity. Just for interest - actualy the basic simple scheme does the most useful functions of selecting coil cuts. John
