Post by knathsif on May 27, 2010 4:15:19 GMT -5
Hi!
An intro's probably called for, since this is my first post here. I've been mucking about with guitar electronics for quite a number of years now. This was mainly kicked off by the QTB mods on the old Guitar Nuts page. Since then, I've become quite handy with guitar electronics and have built a few effects pedals as well.
Now... I've gone and taken up a friendly challenge from a friend of mine which I need a little help on.
Guitar: Godin with H-S-H passive pickups and an LR Baggs X-Bridge with some sort of pre-amp. 1 Mag Vol, 1 Mag Tone, 1 Piezo Vol. (I can't imagine why people would want this without some sort of Mag/Piezo switch...)
Desired Outcome: 3-way toggle switch to switch between 1) Passive (Mag) pickups, 2) Mag + Piezo pickups with blend control, 3) Piezo pickups.
I've decided to try and use the "Active Blender / Volume Module" design as seen here: guitarnuts2.proboards.com/index.cgi?board=schem&action=display&thread=4595. I couldn't for the life of me figure out a way to use a toggle switch to achieve the switching so I resorted to a 3-position rotary switch instead. Here's what I've come up with.
Please excuse the horrible picture. I'm using my lunch break at work to do this so I don't have access to my usual image gear.
SW-1 is the 3 position rotary. Position 1 (dotted) will give the mag signal bypassing the blend unit, Position 2 will give the mag + piezo into the blend unit, Position 3 will give the piezo signal bypassing the blend unit.
The boxed "V"s in the picture refer to the JFET buffer from the Active Blend Module but without the pot. The mag pickup signal will come straight from the pickups (as if the volume pot was at 100% and no load) while the piezo pickup will come through a trim pot replacing the current piezo volume pot (for equalising mag and piezo volumes later).
The boxed "B" refers to the Active Blend Module in its entirety.
I just realised that I forgot to draw in the master volume. It'll go immediately after the Blend Module. Again, I'll be using JohnH's design (for Vol control) in its entirety as well. (Thanks, JohnH et al!! You da man(s)!!!)
I have a few questions relating to this design. I'm not that experienced with active electronics in guitars so please pardon my ignorance.
1) Is there a need for so many buffers or can I just do away with the two buffers before the Blend Module? After all, there'll be another buffer/volume unit after the Blend Module serving as a master volume. Since the piezo has an active pre-amp on it but the mag pickups are passive, I was worried about differing impedances going into the Blend Module.
2) Regarding the Blend Module, I designed the switching arrangement as I would an effects pedal. Reason being I was afraid of some sort of high end loss if the Blend Module was only partially by-passed. Was I correct?
3) Can anyone see a way to do this using a 3-way toggle? That'll be ace!
Thank you all in advance!! ;D
Regards,
Shaun
Regards,
Shaun
