iant412
Post by iant412 on Jun 7, 2010 22:35:25 GMT -5
So here is the general idea: I have a double neck Carvin bass/guitar. It has 2 outputs & a 2 way selector to switch between the bass & guitar. The current 2-way switch has 6 terminals on it. It is wired such that on the guitar 1 wire goes to the pickup selector & 1 to the output jack. Same with the bass. I want to be able to select either the guitar, the bass, or both. They each have volume controls for each pickup, tone control + coil splits. Do I simply need a DTDP On/On/On switch? Stock info on the guitar is here: www.carvinmuseum.com/decade/images/80-dn640.htmlWiring info here: www.carvinmuseum.com/decade/images/80-controls.htmlAs far as I know, and from what I can tell, no mods have been made to it...yet.
Post by wolf on Jun 7, 2010 22:54:12 GMT -5
I'd say what you need is just a single-pole double throw center on switch. This is the switch found on the millions of Gibson Les Paul's and SG's but I wouldn't use the official Gibson switch. It is huge and requires a lot of wood to be removed from the guitar body.
iant412
Post by iant412 on Jun 8, 2010 20:13:16 GMT -5
Are you sure about that? There is a DPDT On/On in there now. Guitar On/Bass On. A single pole would only have 3 terminals. 4 terminals are being used right now. 1 wire from each volume control (bass & guitar) and 1 wire to each output jack (bass & guitar). Don't I need a DPDT On/On/On? I wire Bass volume to top right terminal, Guitar volume to bottom left terminal. Bass to jack middle right, Guitar to jack middle right. Thus I am not using the top left or bottom right terminals. Should this not give me what I'm looking for? Up position - Bass Middle position - Bass + Guitar Down position - Guitar
Post by wolf on Jun 8, 2010 21:27:40 GMT -5
iant412Here's how to do this with a SPDT center-on switch: and since I previously mentioned the Gibson type of switch, here is how that works:
Post by newey on Jun 8, 2010 21:40:41 GMT -5
I think you mean "guitar to jack, middle left" I'm a bit unclear on what you intend here, and the Carvin diagram doesn't help matters much, it's more stylized than informative. As I understand it, you currently have 2 separate output jacks, one for the bass and one for the guitar. Currently a DPDT switch selects either the bass output or the guitar output, but not both at once. Correct me if I'm wrong, but you want a 3-position switch to allow both outputs to be active at once. Presumably, you want to do this so you can be a-bassin', and just move over to guitarin' without flippin' a switch. You should consider that, with both outputs active at once, sympathetic vibrations from the bass will likely induce a signal through your guitar pickups, which will also be active in the mid position. And vice versa, if you're on the guitar- although the bass is probably more likely to cause an issue. I'm not sure the resulting effect is going to be to your liking. I suspect Carvin had a good reason for the either/or setup they used. But, to answer your question, and assuming I'm right about what you want here, you are correct, you need 2 poles to feed 2 separate output jacks. Wolf's way of using a SPDT center-on would result in the guitar and bass outputs being combined (and going to both jacks at once); I don't think he understood you were talking separate outputs.
iant412
Post by iant412 on Jul 17, 2010 19:48:08 GMT -5
Newey...I think you are right.
Christian from El Ten Eleven modified his Carvin in a similar way. I talked to him about it, but he didn't do it himself so he didn't have specifics.
I put in the DPDT switch, however only one pickup each seem to work on both the bass & guitar and tone control doesn't work. I'm going to diagram out the wire routing that they had. Perhaps that will help.
Stay tuned.
Ian
iant412
Post by iant412 on Jul 17, 2010 20:36:40 GMT -5
Can anyone post a picture of the diagram that I drew? Does it have to be hosted somewhere & linked to?
Post by newey on Jul 17, 2010 20:38:45 GMT -5
Inserting the new guitar/bass selector shouldn't have affected any of these things. If your wiring of the new switch were a problem, you'd either get no output at all in one or more positions, or not get the output you wanted at a particular setting. Does the new switch work as intended? Sounds like you may have joggled a connection (or a couple of connections) loose in the modding process. And, yes, a diagram would be a good start . . . EDIT:Iant- We cross-posted. To post images: Image Posting
