Post by Yogi B on Nov 1, 2018 10:52:52 GMT -5
Failing to make the Bridge × Middle + Neck selection work perfectly, I thought about other potential "accidental bonus" settings we could have instead. The most obvious -- given by simply reordering the poles such that the grounding throws are those selected in the centre position -- is a solo switch, of sorts. This would select at most one pickup, the bridge-most of those that are selected in the other two modes, that is: if the bridge pickup isn't off then we're left with just the bridge pickup; otherwise if the middle pickup isn't off we're left with middle; otherwise the neck pickup if the neck pickup isn't off; otherwise (all pickups off) the output is shorted, as with the other modes. If desired, the order of precedence can be altered by differently assigning the pickups to the switches; the current behaviour is probably the most favourable, though in some situations it's easy to imagine one might prefer to transpose the middle and neck.
Post by ourclarioncall on Jul 25, 2020 22:44:54 GMT -5
Brilliant thread this 🙂 so glad I stumbled across it
Post by ourclarioncall on Jul 26, 2020 7:56:36 GMT -5
In the second diagram the 6pdt switch was changed to Johns 4PDT version, but the order of the switch settings was also changed from on/off/on oop , to on/on oop/off
How do I keep it as on/off/on oop?
In other words, I want the first diagram but with Johns 4PDT series /parallel switch instead of the 6pdt
Any ideas?
Post by ourclarioncall on Jul 26, 2020 7:57:06 GMT -5
Just another thought -
For the variation of the series/parallel switch that uses an on-on-on switch and has the bridge*middle+neck .....
Could that be changed to something like a kill switch ? Perhaps this would be a more practical function, as for someone like me that uses circuits with only switches , to turn the guitar off I would have to potentially flick the three pickup switches to the off position , but a kill switch option on the series parallel could be a bonus if the switch is going to have an extra position with a sound that might not be that great or just doesn’t work.
Anyway, just thinking out loud.
The order of series/kill switch/parallel would probably be better series/parallel/kill switch but that might make the wiring multiplied times more complicated to achieve , I dunno.
I find that the on-on-on switches I have are really good and when you try to flick it from one end to the other it tends to stop in the centre. It has a great feel /click. With the cheaper Chinese switches they are a bit more flimsy and easy to push past that centre setting as if it didn’t exist.
But no sweat over the kill switch , i would probably use the option if available , but just series/parallel is fine
Post by aroberts8089 on Oct 2, 2020 21:02:07 GMT -5
Finally back after 10 years (an acoustic hiatus). Good to see these designs are still being discussed. A bit irritated that the "hybrid" setting was problematic. My brother used my scheme in a guitar - I will have to follow up with him to see what his experience was with that middle position. I can see the kill switch option being interesting as well (and would totally be doable I think), but I am a bit obsessed with getting the Bridge * Middle + Neck position to work. Will have to resurrect this project again now that I am playing electric again....
Post by ourclarioncall on Oct 2, 2020 21:11:33 GMT -5
Finally back after 10 years (an acoustic hiatus). Good to see these designs are still being discussed. A bit irritated that the "hybrid" setting was problematic. My brother used my scheme in a guitar - I will have to follow up with him to see what his experience was with that middle position. I can see the kill switch option being interesting as well (and would totally be doable I think), but I am a bit obsessed with getting the Bridge * Middle + Neck position to work. Will have to resurrect this project again now that I am playing electric again.... I just got an email notification that you had liked my comment and I was about to blow the trumpet on here to tell everyone you were back on ! Although I never had the pleasure of meeting you on here as I’m a newbie, I did enjoy your posts and did wonder where you vanished to 🙂 anyway , great to see you back on here 👍
Post by aroberts8089 on Oct 8, 2020 15:31:23 GMT -5
Ah! I think I got this one figured out - Just need to do some more route tracing and confirmation before putting it out there. I started out thinking I would need to do the serial/parallel switching with dual 3PDT on/on switches (this would have allowed for B x M + N as well as B + M x N but in the end I managed to get it back down to a single 4PDT on/on/on. If people prefer a middle off position rather then a Hybrid middle, they could easily throw in an on/off/on switch instead......but in that case there are probably much easier ways to wire this whole thing up.
Post by ourclarioncall on Oct 8, 2020 18:14:17 GMT -5
Look forward to seeing your progress 👍
Post by aroberts8089 on Oct 12, 2020 8:49:19 GMT -5
So it ended up being a bust, unfortunately. It just ended up failing at a different point. At this point, I think I can do it with 2 3PDT on/on switches, but I am not sure its worth the effort for me. For essentially 1 extra sound that I didn't think I was going to get originally anyway it probably not worth it. Since I would now be up to 5 switches for only 2 additional sounds I would tend to just revert to 4PDT on/on and only have a series/parallel option.
OR even better I stumbled upon Hermetico's Guitar wiring Blog this weekend and he uses the first 3 4PDT on/on/on switches to assign the PUP to either the series or parallel route. At first, I didn't care for the idea as I felt that the phase switching felt more intuitive at that point, but now I am sold. I can put 2 phase switches in for 2 pups and with Hermitico's Series/Parallel switches have everything in my design plus.
Instead of spending hours solving a problem that's been solved by better minds than my own, I can wire it up and start creating my music again.
