Post by greeneyezzz on Sept 13, 2010 13:28:50 GMT -5
Hi y'all I read somewhere that when your pickup is too close to the strings (or vice versa it can cause the sound to become blurry because of the strings overdriving the pups in the low freq range. Anyone here has some thoughts on that?
Post by ashcatlt on Sept 13, 2010 14:06:24 GMT -5
I don't believe you're going to overdrive a passive pickup. A hot pup might end up overdriving something else down the road, but...
I've always heard that a pickup too close to the strings can cause a loss of sustain and maybe some higher harmonics due to the magnetic drag.
Post by Yew on Sept 13, 2010 14:30:48 GMT -5
Greeny, in a way you are right, it gives you a much fatter bottom end, generally not in a bad way either. however it can be bad if you didnt want that pickup to sound fat and punchy, but wanted it to sound more balanced, or more trebly
for example when i was using my gretsch filtertron, if i had the pickup close to the strings the tone was always like "back in black." However with the pickup slightly further down, i got a balanced highway to hell sound. Finally with it a fair ways down there, I got a "TNT/ A long way to the top if you wanna rock and roll" sound
NB; this is mainly my experiences for rhythm work for leads i found it was smoother with a closer pickup, and more... articulate when it was further away.
Post by greeneyezzz on Sept 16, 2010 10:04:59 GMT -5
hm thanks
I will need to try this out a bit
