Post by 4real on Feb 18, 2011 7:15:34 GMT -5
fergus
Post by fergus on Feb 18, 2011 18:22:15 GMT -5
Interesting. I can't figure out how to have two simultaneous 'spin a splits' while keeping normal humbucker operation without dual gang pots. hmmm
Post by JohnH on Feb 18, 2011 20:40:00 GMT -5
Well, it seems to offer the 'spin-a split' or 'spin-a-split via a cap' options for each pickup, using the preset sliders. My fear would be that in setting out to control coil splitting on two humbuckers with one singl-gang pot, they have perpetrated some dreadful linking together of the two centre-tap wire pairs of each humbucker. J
Post by 4real on Feb 18, 2011 21:07:04 GMT -5
Potentially it does use a push pull dual gang...my cheaper pull pots i have been using are built this way...that would do it. I wonder though if thye have found a good value for the pots also, 500 was way to big and i think one could do better than 25o audio perhaps.
Interesting idea. In my spin-select research i found that you could use the other side of the dpdt to add splitting to a second HB in the one control, but not variable. It is actually good to be able to mix Hb and SC sounds I've found, so adding such a control to both pups is perhaps not ideal. At least with the simpler one split, one variable, you have some potential to mix things up a little more.
I guess the cost is ok, but it does seem a fair bit for something so simple. The variable treble bleeds and such seem like and interesting idea...did you see them?
