New to the forums, and I will start life off with a lengthy and fairly complex wiring question...
I am fairly new to guitar playing and want to be able to get dual Humbucker sounds more akin to a Les Paul, but I also want to have the single coil Fender Strat sound. (mainly because I like a ton of different styles and don't have enough money to put down on 3 different guitars ) Pretty much I want to make a Les Stratopauler with an HSH pickup combo.
Question is... I don't really know how to wire it up. I know the basics of coil-splitting and switching, but unfortunately this is going to be pretty complex to wire correctly.
So for the combinations that I would like to have
Humbucker sounds...
Neck (Humbucker) only
Neck and Bridge (HB) (no middle pickup)
Bridge (HB) only
For Strat Sounds...
Neck (Coil-split) only
Neck (CS) and Middle (hum-canceling)
Middle only
Middle and Bridge (CS) (hum-canceling)
Bridge (CS) only
And for other combinations...
Neck (HB) and Middle
Middle and Bridge (HB)
Neck and Bridge (North coil of Neck pick-up and South coil of Bridge pick-up)
Neck and Bridge (South coil of Neck and north coil of Bridge)
For pot uses...
Volume pot would stay master volume.
Tone 1 would be neck and middle pickups (instead of just neck)
Tone 2 would become bridge pickup tone only (instead of middle)
I would like to keep the look roughly the same so if it can be done using three push/pull pots and a 5-way super switch that would be awesome.
At the moment I do not want/need any parallel/series or in phase/out of phase options (and I don't know if I ever will want them either)
I will be buying completely new pickups probably (GFS Vintage Extra Hot Pair or a Bigmouth Pair for the humbuckers, and a Texas Special-type for the single coil)
Also, if you have suggestions for other pickups that don't break bank please let me know! (from what I have read GFS are awesome pickups especially for the price, but I have never had first-hand experience with them or know anyone who has)
So if you kept with me for all of that... suggestions or diagrams? =)
After looking through
guitarnuts2.proboards.com/index.cgi?board=schem&action=display&thread=3157I have a pretty good grasp on the stock wiring of 3SC Strats with vol, 2 tone, and 5 way switch...
Unfortunately I would probably need a 5 way super switch and several push/pull pots...
