glynnk
Post by glynnk on Mar 30, 2011 16:53:55 GMT -5
Hi I looking for a wiring diagram to be able to set up as the following.
Selector switch
1: Bridge pup 2: Bridge & Middle pup 3: Middle pup 4: Middle & Neck pup 5: Neck Pup
Thanks
Post by newey on Mar 30, 2011 17:38:26 GMT -5
glynn-
Sorry to have to move your thread, but it doesn't belong in Schematics.
Your desired switching looks suspiciously like the stock Strat wiring, used on literally millions of Strats made since the '70s. Isn't your Strat already wired that way?
Or, do you mean you just want to reverse the switch positions so that "1" becomes "5", "2" becomes "4", etc.? I mention this only because there's no clear convention on which position is #1, whether neck or bridge.
peterrabbit
My mileage DOES vary
Post by peterrabbit on Mar 30, 2011 18:17:44 GMT -5
Post by sbgodofmetal on Mar 31, 2011 9:20:00 GMT -5
I believe this is what your looking for now if you are wanting it reversed just switch the 2 outer wires +Tone 2 around. don't worry about positions 2&4 a standard 5way switch only has 3 terminals in it and a flat bar that moves over them and is wide enough that in those positions it touches 2 terminals causing the combination of the 2 pickups there is no special wiring on a standard switch to get positions 2&4.
glynnk
Post by glynnk on Mar 31, 2011 17:16:54 GMT -5
Hi Everyone thanks a lot for your help all done now works a treat. Just put some new Texas specials on my strat and it now sounds awesome.
