Post by rebel082002 on May 9, 2011 20:36:56 GMT -5
Can you use a 3 way blade switch wired only to a single coil PU so that all it does is have it turn on and off?
If so could you use the 3rd position to go out of phase?
Post by JFrankParnell on May 9, 2011 21:10:36 GMT -5
"oop" means "oop with another pup" so, no But you can easily make it just turn off and on. The tricky part is to not wire the non existent other pup to the switch Probly, you will get your pup on in 2 positions and off in the 3rd.
Post by newey on May 9, 2011 21:17:55 GMT -5
A std. Tele -style 3-way lever switch is a 2-pole switch, so, yes, you can wire it as on/off/OOP, provided you do have another pickup to combine it with in the OOP setting, as JFP notes.
