Post by sbgodofmetal on Jun 11, 2011 11:40:15 GMT -5
Take any HH or HSS guitar and replace the 2 standard tone pot out and replace them with dual concentric pots and wire each coil to a level of each pot for a bridge hb wire the outer coils to the top level of the pots use either a .001uf, .018uf, .022uf capacitor for the bridge outer coil, and .078uf, .086uf,.094uf for the outer neck coil, wire the 2 inner coils to the bottom levels with .022uf, .039uf, .047uf, at the bridge inner coil, and .050uf, .069uf, .078uf on the inner neck or middle coil on hss.
