spower
Post by spower on Jul 27, 2011 21:43:23 GMT -5
Using this diagram www.guitarelectronics.com/product/WDUHSS5L1101How can? Or can I at all use a 500K resistor (I've got some from Mouser,they exist) to make my single coils N and M read 250K from volume. And have the HB bridge read 500K. Would there be problems with the coil split on the HB bridge and M single in position 4? I know I can turn the volume down and do they same thing for the singles but I would rather not.
Post by thetragichero on Jul 27, 2011 22:15:09 GMT -5
i'm sure it could be done with a superswitch?
Post by newey on Jul 27, 2011 23:38:30 GMT -5
spower-
I'm a little unclear on what you're asking here. The link to your wiring shows a master volume and tone. With a SSH setup, pot values are always going to be a compromise. With a master V and T, a 500K pot may be a bit bright for the SCs; 250K may be too dark-sounding for the HB.
But adding a resistor is not likely to help matters much. The difference shouldn't be that big a deal that you can''t live with it. If it is, I'd say split the difference and use a 300K pot instead. These do exist although not as common as 250 or 500.
Post by ChristoMephisto on Jul 28, 2011 7:29:27 GMT -5
Tried that once and the volume pot behave weird. Think Fender has a HS tele with a 500k pot and it drops a 270k resistor across it when Bridge only in selected. It totals 170k, maybe it works...
Could try to get a dual/stacked/concentric 500k/250k pot
spower
Post by spower on Jul 28, 2011 16:12:12 GMT -5
I've found a happy medium. 768K resistor to the outer lugs of the volume. Now I have a 330K Pot. for singles and HB. If that ends up not being enough for the HB I'll raise the resistor value.
