popsaka
I'm tired a'playin' so low...
Post by popsaka on Jul 30, 2011 18:27:06 GMT -5
...Hey, kids... On a tunematic bridge can you lift out the saddles and reverse them if need be for intonation? Now lets see if I can guess... You back the screw out as far as it will go and then it lifts out?
Post by cynical1 on Jul 30, 2011 19:41:33 GMT -5
Yes, you can flip them. And yes, it works pretty much like you've already figured out.
Keep in mind, it's not going to give you a tremendous amount of wiggle room, but if you're only off a couple of cents it might do the trick.
Which side are you flipping, just out of curiosity...
Happy Trails
Cynical One
popsaka
Post by popsaka on Jul 31, 2011 6:06:20 GMT -5
...the bass side, specifically the A just won't quite sharpen up to the harmonic... I suspect also that a new or heavier string may solve it... Its a Chinese Les Paul... really nice. A student of mine just got it off Ebay for 200 US ...Humbuckrs all gold trim, Chinese Grovers and (egad) painted pale pale yellow but nice, none the less... The intonation/tuning has been the only problem
Post by cynical1 on Jul 31, 2011 7:53:03 GMT -5
Well, that makes sense. Typically where you have to cheat. The only thing that concerns me about knock-off guitars is the potential lack of attention to details you find on them. The tune-o-matic bridge is generally angled when mounted. A common rule of thumb for intonation versus scale length is subtract 5/64th from the high E and add 3/16" to the low E. Again, this is just generic, your results and mileage may vary... Here's a good generic representation of how the bridge and tailpiece relate to each other: This can change, depending on several factors, but you get the idea. This can be a deal breaker if the drilled mounting holes are off for the scale. I'd say for $200.00 the Chinese knockoff in question does not have a compensated nut, but a bad cut on the nut can also effect the ability to intonate the guitar. Another thing to look at is string height. Sounds like a non-issue, but at the octave you can get the harmonic in intonated, but the fretted note goes South on you. Just for reference, when you check the intonation on the A string, how much of a difference is there between the fretted note and the harmonic at the octave? Hope the saddle flip works. Happy Trails Cynical One
popsaka
Post by popsaka on Aug 3, 2011 10:04:26 GMT -5
...I won't be able to service the ax 'till this coming Sat. but backed up for the shortest possible distance from bridge to 12th fret it was still a little flat... just a fraction of a microtone but enough so that one in five block chords would be out of wack... in other words, not tune-upable ;-) BTW I keep lowering the action -its down to a nickle at the twelfth fret on the treble side and still no buzz anywhere -plus because the low 'E' intonates normally I still suspect a new 'A' string might bring the thing around...
Post by Yew on Aug 3, 2011 15:57:20 GMT -5
On some tuno's, turning the bridge around so the screws are on the other side can help however I cant remember if it is ABR's (thin ones with a wire touching the strings) or Nashvilles (thicker body, no wire) that it works on
popsaka
Post by popsaka on Aug 3, 2011 21:20:06 GMT -5
...hey, I never thought of that..;-)
